Whinning and howling rear
I'm buying a completely stock Z28 from my friend who just purchased the used rearend from a salvage yard because it was whinning and howling. This fixed the problem for about a month. Now it is starting to do the same and I don't know if there is something causeing this or just bad luck. The howling sounds like it is coming from the gears and the whinning sounds like it is coming from the driverside rear. Where do I begin?
I had someone check it out and yes it is the rear. My plans are for this car is to eventually be running about 400-500hp. What can I do to make a stock 10 bolt last or do I need to find a 12 bolt that will work?
