How to disable ABS light in a 98?
Old 11-08-2008, 11:11 PM
SladeX's Avatar
Default How to disable ABS light in a 98?
Quick question, in deleting ABS from the car, how would you go about shutting off the light without resorting to the black tape mod? I heard 98 and lower can disable the light easily without tuning.
Old 11-09-2008, 09:40 AM
Blk_Ws6's Avatar
Mines on to the sensor in the rear end is out on your car.
Old 11-09-2008, 10:29 AM
GregWS6&z28's Avatar
i pulled my gauge cluster and opened it up and put a piece of black tape over the bulb
Old 11-09-2008, 10:35 AM
SladeX's Avatar
Let me re-iterate the idea that 98 and below can do something other than put black tape to shut off the light.
Second, my ABS works, but I'm going to swap to a rear without ABS and have a proportioning valve so I need a way to shut off the light.
2nd poster, that's pretty vague of an answer?
Old 11-09-2008, 10:52 AM
05MBMLS2's Avatar
1- Rip out bulb
2- On a 98..you can ground...
pin 7 to pin 12 turns the ABS INOP light off.
pin 16 to pin 12 turns the BRAKE light off.
Old 11-09-2008, 12:30 PM
Engine_HP's Avatar
Originally Posted by 05MBMLS2
1- Rip out bulb
Old 11-09-2008, 01:23 PM
03 BUSA's Avatar
What about those pesky TCS lights?
Old 11-09-2008, 04:27 PM
05MBMLS2's Avatar
Originally Posted by Engine_HP
This worked for me.....
https://ls1tech.com/forums/showthrea...&highlight=abs
Old 11-09-2008, 04:49 PM
Engine_HP's Avatar
will it work on my 99 ?
anyone tried it ?
thanks
Old 11-09-2008, 05:16 PM
03 BUSA's Avatar
I am pretty sure it will not. The 99 and up have different wiring than the 98's did.
Old 11-09-2008, 05:23 PM
Engine_HP's Avatar
i was pretty sure too be4 i asked the Question but i thought i might have a different answer (HOPE) looool,
thanks anyway
Old 11-09-2008, 05:49 PM
bad6as's Avatar
yea i thought i read some thing a while back about grounding some wires on the 98s but never knew for sure if it works
Old 11-09-2008, 08:04 PM
SladeX's Avatar
pins under the console...? pins at the ecm area? pins is quite the vague description...
Old 11-09-2008, 08:26 PM
03 BUSA's Avatar
Originally Posted by sladex
pins under the console...? Pins at the ecm area? Pins is quite the vague description...
pcm...
Old 10-02-2010, 12:29 AM
srpoweredcoupeNWH's Avatar
I know this is an old thread but I wanted to make sure you did it at the pcm and not the abs connector and if it was the red or blue connector.
Old 06-10-2013, 07:35 PM
decipha's Avatar
The pins are at the ebcm connector, when you flip over the connector after pulling out the blue clip to release it, you will see the numbers marked on the connector itself
The wires are green, yellow/blk, and the main ground wire is a black 12 gauge-ish
Does anyone have a remedy for the tcs lamp?
I'm updating this old thread because some folks might find it in a search, such as I did
Quick Reply: How to disable ABS light in a 98?
