moser 9 w /430 gears
Old 12-17-2008, 10:35 PM
blackls1ta00's Avatar
Default moser 9 w /430 gears
i have a 383 stroker almost finished,im looking to do a moser 9 with 430 gears in the spring before the track opens,i will be running a 28 mt slick.i also will be using a wet 150 shot.will i be ok running thru the traps in 4th with a 430 gear and 28 slick on a 150 shot?my cam is a g5x3.
Old 12-17-2008, 10:39 PM
the_merv's Avatar
What RPM's you plan on shifting at?
Old 12-17-2008, 10:56 PM
Old 12-17-2008, 11:01 PM
danhr's Avatar
should be fine... unless you plan on trapping over 140 mph
Old 12-17-2008, 11:02 PM
getusum's Avatar
x2.......
Old 12-17-2008, 11:31 PM
130 or mid 10s is fast enough,thanks for the help guys
Old 12-18-2008, 09:32 AM
any other opinions would be great i am only wanting to buy these gears once 411 or 430?
Old 12-20-2008, 06:18 PM
99zMD's Avatar
Moser 9in. w/4.30's here and doin just fine.
Old 12-22-2008, 08:27 AM
what are you running in the quarter mile?are you using nitrous also?this is my first time using n20,thanks for help
Old 12-22-2008, 10:47 AM
Jawsgear's Avatar
You can run all your calculations from our website calculators to verify specific trans ratio and rpm with tire size and ratio. Here is a link...
http://www.jawsgear.com/calc_rpm.html
Hope this helps.
Jeff
Old 12-22-2008, 12:56 PM
BriancWS6's Avatar
You will be good for 135+ with that gear and tire. Same setup as I have. Stick with the 4.30s
Old 12-23-2008, 06:32 AM
thanks man how awesome is it on the street,im thinking about a spool with the 430s.
Old 12-23-2008, 06:55 AM
99zMD's Avatar
Good stuff on the street, she will **** and git no doubt about it. I am not running nitrous, just cam and bolt on's....
Old 12-23-2008, 10:15 AM
danhr's Avatar
if you are concerned about what it's like on the street, you can go for a ride in my car?
and as far as mpg goes.... i got 28 mpg w/ the 4.30's when I drove to memphis for the lsx shootout
Old 12-23-2008, 07:15 PM
BriancWS6's Avatar
I like them on the street. I went from 4.10s in the 10 bolt to the 4.30s in the M9. I could tell a difference but it wasn't nothing major, but it was noticeable.
