98 ls1 400rwhp
Old 01-08-2009, 09:33 PM
bullardsls1's Avatar
Default 98 ls1 400rwhp
98 ls1 400rwhp next project trick flow heads and a good dyno tune
looking to make as close to 450 rwhp as i can what can i do about the rearend i was told a 9 inch will slow my car way down what about beefing my factory 10bolt or 12 bolt
Old 01-08-2009, 10:08 PM
AFASTYZFR1's Avatar
run your 10 bolt till it breaks, then just get a 9" so it will handle whatever you throw at it next
Old 01-08-2009, 11:04 PM
Avaric3's Avatar
on the dyno youll lose some power wit a 9" but youll gain in the 1/4 from that harder launch
Old 01-08-2009, 11:05 PM
jetlag's Avatar
I'm going to have to disagree with this... Sell your 10 bolt and get a couple hundred for it to help ease the cost of a 9"
Old 01-09-2009, 11:17 AM
Carter01's Avatar
Just look at my signature, only thing that changed was a new Moser 9 from Bob at EPP and a little better weather, same track, same driver etc.. When you are actually able to launch the car you will gain times. Also do a search on HP loss, I think it was GMHTP that did back to back dyno testing. Don't quote me but the results were something like this, 9in = 1% hp loss, 12 bolt = 1% hp loss and the Dana 60 was like 4% hp loss. My good friend installed an Dana 60 in his Camaro and lost 15hp which was almost exactly 4%. GL
Old 01-09-2009, 11:32 AM
1redta's Avatar
Default jkdf
I thought the 9" had the highest loss b/c of pinion to gear angle,
the 12 bolt a little less, then the 60 was the most effecient.
Old 01-09-2009, 01:29 PM
Sprayed 99's Avatar
i 100% agree. people make such a huge friggin deal about power loss. but when it comes down to it, if u cant get all the power to the ground then what the **** is the point?
Old 01-17-2009, 06:51 PM
NSSANE02's Avatar
Yeah the 9" won't take anything away from your performance, I dropped .2 in the 1/4 and actually gained 2 mph after my 9". Whatever you do, don't touch the 10 bolt... that's just a waist.
Old 01-18-2009, 06:13 AM
EPP
EPP's Avatar
Thumbs up
Thanks for posting, a lot of people think they're going to slow their cars down when they swap out their 10 bolts. Bob
