ta cover
ta cover
I just recently purchased a used lingenfelter ta cover for my 10 bolt and it is missing some bolts. Primarily the longer ones that go towards the top, since I don't have either of the 2 I was wondering if anyone had any ideas of how long and the type of thread they were? I already wrote to lingenfelter just seeing if I can get a quick response here-thanks.
Here is a link for you.....the kit runs$19.95. Look under TA_1809 cover, stud kit is TA_1815.
http://www.taperformance.com/products.asp?cat=48
Thanks guys, I already put it on and took off the clips, so I used a bunch of short ones, if/when I go back in I know what they are now.
HAVATAMPA I just finished putting that damn thing in at 7pm last night so close.
Curious, what are you using to seal it with? I hope you have better luck with leaks than I do. I've used a dry gasket, I've used no gasket wirh silicone, I've used a gasket and silicone. Always starts leaking at the bottom even after retorqueing several times. This time I'm going straight copper sealant and no gasket.
There is a product called "The Right Stuff" within 5 minutes of applying it to the girdle it has to be put on. Luckily when the old cover came off the old gasket came off w/ it, so cleaning did not take that long. No leaks yet and after fridays installation I took her to the track on Saturday and abused it about 10 times and still good.
