axel replacement bearing problems
has anyone ever had any problems with a sqeaking noise from the drivers side when making right turns? i replaced the passangers side no problems. but the drivers side was hell to get the c clip in now it makes noise really low speeds and while making right turns and goes away when making left turns...
i have the same problem... and have no idea what it is... actually it went away this winter but im not sure what i did to fix it...
the only thing i messed with really was i tightened the bolt that holds the rear shock in its lower perch deal.... i dont remember if that fixed it or if it just went away over time....
you may check those to see if that is your problem cuz i had one side that was pretty loose...
what would be the outcome if i replace the bearing and re-install the bad axle??,,,i ask because i still have a whine,,and vibration and when i replaced the wheels i noticed that one was bent,,,,is it possible to bend an axle,,and how can i look at it and tell???
