posi rearend?
Old Feb 4, 2009 | 06:54 PM
lee33lyn's Avatar
Default posi rearend?
I heard that if you jacked up the rear of your car and spun the tire, and both tires rotated the same direction,then it had a posi rear. Is that true?
Old Feb 4, 2009 | 08:33 PM
9000th01ss's Avatar
Thats true with most types of posi differentials. But a torque biasing diff like a factory installed Torsen will act just like an open diff while spinning the tires with it jacked up.
Old Feb 5, 2009 | 06:25 AM
lee33lyn's Avatar
so how do i tell what equipment is in my 95z28? the code says 3.42 gearing,but I think its been worked on. I just bought the car about a month and seen a receipt in the dash for rearend work. I've got the cover off to change the oil but I don't know what I looking at.
thanks Lee
Old Feb 5, 2009 | 06:38 AM
Badazz 97 TA's Avatar
do a burnout.....?????
Old Feb 5, 2009 | 07:10 AM
nighthawk15's Avatar
LS1 or LT1 car? The LT1 cars only ever came with Posis except for a some SLP (SSs and such) cars IIRC. Pretty sure the dif cover looks different on the Torsen cars too.
EDIT: pic of a Torsen on a 96SS
Old Feb 5, 2009 | 09:11 AM
lee33lyn's Avatar
Its an Lt1 car.My rear end cover is the simple smooth painted one.
Old Feb 5, 2009 | 10:22 AM
9000th01ss's Avatar
Both my 01 Z28, and 02 SS have Torsens with steel covers.
I attached some pics of a Torsen diff out of a 2000 SS.
This here is some kind of open diff I found with google, same thing yours will look like if it's an open diff.
Old Feb 5, 2009 | 11:12 PM
Its a posi then unless somebody changed it.
Old Feb 6, 2009 | 06:22 AM
lee33lyn's Avatar
I'm gonna change the fluid in it. Should I use the gm additive for posi?I can see springs in the center of my carrier,if that helps.
Old Feb 6, 2009 | 06:41 AM
streetassasin's Avatar
Check the door jam for G80, its the rpo for a posi
Old Feb 6, 2009 | 06:42 AM
9000th01ss's Avatar
If you see springs then it's an Auburn posi. Assuming it's the factory installed one, Auburn isn't the only type with springs.
You need GM additive, Auburns will make noise wwith the cheap parts store type that comes in a tube.
Old Feb 6, 2009 | 06:43 AM
9000th01ss's Avatar
I think if this person has the cover off, it should be obvious what it is by looking at it, they said it has springs. It is a posi.
Old Feb 6, 2009 | 06:50 AM
lee33lyn's Avatar
Well, the thing that confuses me is that when i bought it I did a burnout with a buddy behind me and both wheels spun. Later, I did it again and only one wheel spun.I'm new to the 4th gen and don't know what all they came with.Just looked and there is a gu6 and a g80 in the glove box.
Old Feb 6, 2009 | 07:19 AM
9000th01ss's Avatar
What year car is this?
Nevermind is a 1995, seems like a posi doing one wheel burnouts in a '95 might be worn out.
Old Feb 6, 2009 | 07:25 AM
^This^
It happens to every posi at one point or another. It's just the nature of the design.
Old Feb 6, 2009 | 01:16 PM
lee33lyn's Avatar
there's a receipt in the glove box for a rearend replacement only a few months before I bought the car,but there's no details about it,just cost.
Old Feb 6, 2009 | 03:06 PM
9000th01ss's Avatar
Does it say where the rear came from?
You have a clutch type posi rear. There are tests you can do to see if it's worn. For example, jack one tire up, put it in neutral, see how much torque it takes to turn the wheel in the air (this measures clutch slip).
The preload springs are only there to give you 'preload' This is a push on the clutches to provide resistance at rest.
What really locks a posi is the upset force when you have decent grip on both tires and you accelerate hard, the gears (in the posi) try to seperate. This seperation force pushes the side gears against the clutches and locks them.
You can google a lot to find info. Like Google Auburn and read their website.
Google limited slip theory, etc.
I don't know how good a teacher I am, but reading it right off the manufacturers website gives you a sense of seeing correct info vs some random persons info.
Old Feb 6, 2009 | 03:37 PM
lee33lyn's Avatar
I think they replaced the ring and pinion (spelling?)only,not the carrier. I can see the scars on outside of the carrier from the ring gear coming apart.I've put several hundred miles on the car and the rear seems fine.I'm redoing the fluids,bushings,brakes getting ready for my first HPDE at VIR in a couple weeks.
