View Poll Results: Spend $500 to fix stock 10-bolt with 10 second plans?
Yes
2
8.70%
No
21
91.30%
Voters: 23. You may not vote on this poll
Worth fixing the 10-bolt with 10's in mind?
LS1TECH Sponsor
Depends - how many times do you want to spend that $500 to have the rear fixed?
IMO - upgrade to a 12 bolt (since you're automatic) and be done with it.
Check out our very competitive Moser pricing in our Online Store - http://www.tickperformance.com
Do not do it, this issue has been kicked around about 500,000 times! The 10 bolt will not allow your car to reach its full potential. Get either a 12bolt or 9 inch. I run a 9 inch in my car, and love it.
dont waste your money on the 10 bolt! when i had my camaro i dumped about 500 dollars a year into the 10 bolt. over the course of 3 years i owned the car i would have been better off just buying a real rearend in the first place. then i wouldnt have been afraid to really beat on the car. it was an automatic. now on my M-6 Trans Am, i just sucked it up & bought a 9 inch for it. i wount have any worries about the rear breaking when i launch it.
I could try selling the 10 bolt if i take it out. It has new bearings, an auburn diff (albeit being worn out), 3.42 gears, and moser axles. Gotta be good for a couple hundred?
idk about the girdle. i have one on my 10 bolt right now. i have 4.10 gears, torsen diff, arp studs, and the girdle. im on my 2nd (going into 3rd since its broken) 10 bolt. first time the spider gears blew out, so i replaced it with a torsen, girdle and studs wer on both. #2 has an inch long crack in the case on the driver side. i havent pulled the cover off yet to see whats left but i doubt its much. if you have the money (which i dont) buy a 12 bolt or 9"
or if u cant quite afford them, go with the rare 8.8 conversion. probably what ill do when i have a constant source of income
The Moser M9 rear comes with a great chrome moly torque arm and transmission crossmember. Here is a link to this rear, which weighs the same as the 10 bolt to boot! http://www.exoticperformanceplus.com...html?item=1324 Bob
