4.30s
Old Feb 5, 2009 | 06:31 PM
bad70ss's Avatar
Default 4.30s
I am looking into buying a car with 4.30 gears and a m6 trans. I was wondering how much this will hurt the gas mpg and how it would be for a dd (summer months mostly). Also, cruising on the highway around 75-80, what rpm are you guys at.
Thanks again
Old Feb 5, 2009 | 08:31 PM
silverLSWON's Avatar
i drove 13 hours each way from pittsburgh to memphis and got 29.6 mpg with the mods in my sig. my worst mpg was 25.3
Old Feb 5, 2009 | 08:45 PM
silverz28camaro's Avatar
The great thing about the m6 is the the 2nd overdrive(6th) is a .50 ratio, us auto guys are .70 in out over drive, my car is auto with 3.73 and can pull 22 mpg on the highway wiyth ls6 head, torque v2 cam
Don't worry about those 4.30"s unless its in a 10 bolt!!!!! BOOOOMMMMM!!!!
Old Feb 5, 2009 | 08:50 PM
Randy WS6's Avatar
I love my 4:30's , the best gear for me.
Old Feb 5, 2009 | 08:51 PM
Camaro Jearmy's Avatar
got 4.30's in a 12 bolt 6 spd...65 mph turning about 18-1900
Old Feb 5, 2009 | 08:55 PM
bad70ss's Avatar
That makes me feel better, I assume highway will not suffer, but around town will? And yes its a 10 bolt
Old Feb 5, 2009 | 09:36 PM
Around town shouldn't change, If anything the car should take off with a little less throttle. You maybe able to skip from 1 st to 4th to avoid burning to much fuel, but i'm not sure ask the m6 guys.
Don't worry about mpg, half the time you will be at WOT anyway so let it go.
Old Feb 5, 2009 | 10:26 PM
studderin's Avatar
I love my 4.30s and I was on a smaller 25.5 tall street tire. Going to a taller DE this year for a street tire. Like silverLSWON Drove I think it was 16hrs driving time over 2 days tio the shootout. 80mph is about 2,200 rpms, M6 its fine. Somtimes going 1-2-3-4-5 at 10-20-30-40mph around town can ge alot, but is easy skip, 2-4 not the big drop. And 2nd starts are fine if your moving a little.
Street tires top of 4th is about 115, but on 28inch ETdrags should be around hi 130's.
Old Feb 6, 2009 | 10:44 AM
jmm98LS1's Avatar
I still got 24mpg with 4.56's in a heavy 9" and heavy 17x11 wheels. Got 4.30's in it now, gets around 25-26.
Old Feb 6, 2009 | 11:12 AM
BlackScreaminMachine's Avatar
Internet Mechanic
If your going to roll with that gear, the car's tune will need to be set up to be lean from idle to about 2.5k and when the car goes to WOT, the A/F will drop down to the appropriate level given the engine setup.
