Stock torque arm Moser 9"
Old 02-06-2009, 03:58 PM
jetlag's Avatar
Default Stock torque arm Moser 9"
So I've seen plenty of posts with people using 9" rearends and stock torque arms...so what is my problem?
Here are some pictures. Both lower control arms are on the rearend, but there is no way the torque arm is going to work. It's like it is too long.
(Yes, I know the torque arm is on the wrong side of the mount..lol..but it is impossible to get both LCAs bolted in with the torque arm bolted in. I can get one LCA in, the torque arm on, but the other LCA is way off...so the T/A is too long)
Old 02-06-2009, 04:17 PM
PowerShift408's Avatar
Do you have the LCAs adjusted to where you want them to be when the car is on the ground? Is the torque arm all the way into the tranny mount?
Past that I'm not really sure, I ran a stock torque arm on my 9'' for a long time.
Old 02-06-2009, 04:21 PM
jetlag's Avatar
Stock LCAs.
Old 02-06-2009, 04:55 PM
I know this is simple stuff, but make sure the torque arm is all the way in the mount. Also, are the jack stands supporting the frame or the rear end?
Old 02-06-2009, 05:18 PM
jetlag's Avatar
It is all the way in, and the stands are supporting the frame.
Old 02-06-2009, 08:41 PM
02 BLK WS6's Avatar
Unbolt LCA, bolt up tq arm to rear end, bolt in 1 LCA, use ratchet strap to pull rear end to line up other LCA bolt = problem solved? Maybe but worth a try
Old 02-06-2009, 09:11 PM
Jacks should be under the rear end. That may be the solution.
Old 02-06-2009, 10:51 PM
jetlag's Avatar
It shouldn't have to be like that..lol
Old 02-06-2009, 11:57 PM
02 BLK WS6's Avatar
You're right, but who installs a $2k with stock suspension?
Old 02-07-2009, 12:03 AM
Someone who broke their 10 bolt and didn't want to waste money rebuilding the damn thing.
Old 02-07-2009, 12:25 AM
xxbottlefedxx's Avatar
ok well you said you shoudlnt have to do that but i had to lock in the torq arm and then put in one lca at a time. and so have alot of the people i have helped
Old 02-07-2009, 08:43 AM
jetlag's Avatar
That'll be your business when you start funding mods for my car.
Old 02-07-2009, 09:13 AM
BarneyMobile's Avatar
Amen to that!
I still have my stock T/A with my 9". It was tight for me too. I attached the t/a first then put the LCA's in last. I had to give the rear a good push in a forward direction to get the LCA bolt holes to line up. Now my t/a sits farther into the mount than it did with the 10bolt. Good luck!
Old 02-07-2009, 09:47 AM
02 BLK WS6's Avatar
Think what you want. I shared my opinion and if you got insulted, so be it.
Old 02-07-2009, 05:52 PM
sportfan's Avatar
The Moser nine inch will require an aftermarket torque arm for proper installation. The twelve bolt works with the stock torque arm, but not the nine inch.
Old 02-07-2009, 07:03 PM
I have a stock torque arm on my Moser 9'' right now.
Old 02-07-2009, 07:07 PM
jetlag's Avatar
Well, obviously you're lying. haha
Tomorrow I'm going to loosen the front of the torque arm and try to push it forward...maybe it did pull out or something.
Old 02-07-2009, 07:26 PM
Man-Crush Warning
01sscam's Avatar
I'm running the stock torque arm on mine as well. I've had it on and off many times, I haven't had any problems.
Old 02-07-2009, 07:28 PM
ShevrolayZ28's Avatar
That's how I got mine on. FWIW, I'm pretty sure Matt at Moser will tell you it won't fit, but as you can see at least a few of us have gotten it on there.
I know another guy in my area doing it. His ride is a stroker/turbo car.
Old 02-07-2009, 07:59 PM
sportfan's Avatar
While I know there are many out there that have made it work. It is recommended to use an aftermarket adjustable torque arm. Obviously the OP is having troubles and this might be his best plan of attack. My goal is to not to start an argument, but to assist the OP with his particluar issue.
Quick Reply: Stock torque arm Moser 9"
