need help
need help
I am installing a Moser 12 bolt into my buddies 97 Z28. On the axles i pressed the reluctor (sp) ring , then backing plate, spacer, bearing, and last spacer. how to get get into the inset hold to bolt the backing plate to the housing? Or did i mess up by pressign the reluctor plate on the new axle? If the rear end dont uses the reluctor plate, what does the ABS and TC use to signel the sensor?
thanks for your help.
Is this a three channel set up or a 4 channel setup? A three channel picks up from a reluctor ring at the differential and a four channel picks up from the axle reluctor rings. Did this car have traction control? Did the original rear have reluctor rings at the axle. If not it is probably a three channel and will not require the reluctor rings.
I though it was a 4 channel because it has abs and traction control. It has reluctor rings on each axle. the space between the reluctor ring and break backing plate is where i am having problems.
Yeah I see that. Maybe someone with a four channel setup can chime in here. Mine was a three channel with a pilot hole. Pilot hole won't help here with the reluctor ring. Is the
ABS ring all the way on, difficult to tell from the pictures? Close quarters for sure can you fit a wrench in there?
