Going To Be Changing Rear End Fluid....
I had a couple questions.
1) Do i want to put a bead of rtv silicon (black) down with a new gasket?
2) How many qts of gear oil do i need?
3) what weight is recommended? my car is not a DD see maybe 2,000 miles a year
4) What brand? I have seen Valvoline and maybe Mobil 1
5) Syn fluid or regular fluid?
6) for my 2002 Trans Am do i need the friction modifier? How do you know if you do not need it
7) Do i need to re torque the bolts or just nice and snug.
sorry for all the questions. I have done a search and got mixed result from people
Thanks
Thanks
if u wana put silicon then thats up to you for added seal but the gasket should be fine. Usually bout a quart will do just fill it up until you can stick your pinky in the hole and feel the fluid, and synthetic would be a good idea. as far as bolts should tighten them down pretty good and snug, but tighten down in a sequence evenly each time and you will get a good seal.
You can use a gasket or just silicone alone, I've always used silicone and never had a leak. Holds around 1.5 quarts, just buy 2. Synthetic, 75w90 is what I've done. Some nice brands (Amsoil, etc) have the limited slip additive built in, if it doesn't then you can buy a small bottle along with the gear oil at the store. Fill it up until it starts coming out of the fill hole, let it get even with bottom of the hole then put the plug back in. Sticking your finger in to check level is not a good idea for the most part, you want it extremely clean inside and as soon as you do it any dirt, contaminants, etc on your finger(most likely going to have dirty hands since you're under the car doing this) are now inside the housing. Space tightening the bolts out and snug them down.
I used a new Felpro gasket dry and it was fine, just put a little bit of gear oil on it to help to seal
2 quarts
75W90
Mobil1 is fine but the Royal Purple I picked up from Kragen had the friction modifier already in it...with a torsen style differential that you have the friction modifier is not required but recommended
use synthetic fluid, it states it in the owners manual, regular fluid is required for the auburn (or eaton) units (which you don't have unless it isnt stock)
See above
I just tighten them snug, you dont want to overdo it. I believe the spec is like 10-15ft-lbs, so I just estimated it, hasn't leaked since I did it a year ago
2 quarts
75W90
See above
Torsen=limited slip differential, the additive is not required with the Torsen differential but it is recommended to reduce noise (I believe GM issued a service bulletin for this) but definitely use synthetic.
Rear Axle (Standard Differential)SAE 75W-90 Synthetic Axle Lubricant
Rear Axle (Limited-Slip Differential)SAE 75W-90 Synthetic Axle Lubricant. Add 4oz Limited-Slip Axle Lubricant Additive
And this is th GM TSB:
Originally Posted by GM
Is it true that the Torsen unit in the production Camaro needs the GM modifier added?
Yeah, I understand, I'm just saying that if you don't have the "rusty noise" issue then the friction modifier is not required but it is recommended. They probably updated the manuals some year to add the friction modifier to avoid the hassle of getting future complaints. I ran Mobil 1 without the additive in my 90 camaro with a take-off torsen differential and had no problem, and ran it on my current 02 Z28 with no problem but during my last gear oil change I used it (Royal Purple).
I have no idea if LSD additive was added in or not....
odds are it has never been changed. Just go to you local auto parts store, get some 75W90 synthetic fluid (Mobil 1, Royal Purple) and pick up some GM limited slip additive (only a few bucks, might as well add it, definitely a job you only want to one once, might only be able to get it at the dealer, not sure). I used a Felpro gasket because the first time I changed the fluid I used RTV sealant to make the gasket but I didn't wait long enough for it to dry, so when I put the cover back on and added fluid it leaked, so I redid it with the gasket, and not a drop since.
Get 2 qts of either M1 or Valvoline Syn. either 75W90 or 75W140 or 80w90, get the GM LSD additive, Felpro gasket with black RTV sealant....
You should use synthetic, if you didn't see it try another place, it is required! Not saying that something will go wrong but why risk it. Also, if you use a gasket you don't need any RTV, it is either one or the other.
Well, the first link is referring to the auburn differential (which requires a bit more friction than a torsen differential to work properly) which you don't have but I guess others have used the valvoline stuff with torsens. I'm sure you won't have any problems. I just like using synthetic in a location that recommends it, less friction, longer life, less parasitic losses, and it is a location that you will only change out about every 20K miles.
Like i said i have no idea what is even in there now
see here are some other answers about syn. I give up.
https://ls1tech.com/forums/7878344-post4.html
https://ls1tech.com/forums/7903746-post2.html
https://ls1tech.com/forums/7024808-post9.html
