Which U-Joint with 12Bolt and stock DS?
I just ordered a 12 bolt, but I got it used and need to know what u-joint to purchase so I can get this thing in my car this weekend and be able to drive it.
If its needed its a Moser unit, and I know I need to loctite the TA bolts, any other advice for the swap?
thats weird it didnt show it for me either on the napa site i know thats the part number tho i just bought one last week from the napa store. anyhow here are the numbers so u know
Neapco/pdq 3-3140
Brute Force 3-3140bf ( autozone)
Rockford K460
Spicer 5-460x
Precision 348 (o rileys)
Napa 447
Neapco/pdq 3-3140
Rockford K460
Spicer 5-460x
Napa 447
Neapco/pdq 3-3140
Rockford K460
Spicer 5-460x
Napa 447
Neapco/pdq 3-3140
Rockford K460
Spicer 5-460x
Napa 447
They hire the dumbest people ever in the parts stores here, So I need a 1310 to 1350 conversion u-joint is that correct, and I will need the 330-10 u-joint bolts listed above to fit the 1350 side to the pinion am I understanding that right? I think I might strangle someone today.
ya those part numbers are the 1310-1350 u joint and correct u just need the 330-10 to bolt that in the yoke of the rearend. you should be good to go after that. Ya there pretty dumb. just dont cross reference any napa part to autozone or orileys they will give u some goofy ****
I just went to Napa and got the P447 and it was NOT the correct u-joint, I went back and got the Precision 348 that Napa has and it is NOT the correct one although it does fit the yoke (cap size and length) it does not fit the drive shaft. The stock cap is 1.122 in diameter and the cap on the 348 is 1.188. Any other suggestions!!!!!!!!!
I now have my car in the driveway with no rearend under it. HELP
I don't know if this will help but the stock driveshaft is not a 1310, its a saginaw 44 or
3R and your rear yoke is a 1350. A lot of folks here are saying the Napa 0447 is the correct u joint. I am sure the Neapco 2-1153 is the correct u joint although it is a serviceable U joint (grease fitting). From what I can figure out it cross references to a precision 447.
Ive been wondering this as well. Trying to bolt up my drive shaft to my 9" and it seems the end caps are slightly too long. The driveshaft was JUST bolted up to an exploded 12 bolt. So I figured it already had the 1350.
Is NAPA part # 447 an adaptor or an actual U joint? If so, do I have to bring my driveshaft up and have it installed?
