driveshaft length
driveshaft length
I'm running a stock 10 bolt W/auto in my 02 camaro. I am upgrading the engine and I want a stronger driveshaft. I know a stock length driveshaft using the rear 1350/1310 U joint will work on the 10 bolt but will it need to be shortend it when I go to a 12 bolt rear and use 1350 U joints, or will I be OK?
The 10 bolt and 12 bolt both take the same length of driveshaft. Here is the driveshaft that I use and recommend. http://www.exoticperformanceplus.com....html?item=541 Bob
It should work with your UMI DS loop. This driveshaft is larger in diameter by .50, on either side it is only .25 larger. Thanks. Bob
I have the option at this link for the 10/12 bolt length and the 9 inch length.
http://www.exoticperformanceplus.com....html?item=541 Thanks. Bob
