Should I change the gears in my car?
I have a 02 ss camaro, it has 3:23 gears, 3500 converter, 3" ypipe, and subframe connectors. I am going to put LT's with a magnaflow, ported throttle body, slp maf, 100 or 150 shot, and some suspension work and tuned. Not going to spray it much but want it if I ever need it. Should I change to a lower gear like a 3:42, 3:50 something, or 373? I run 1/8th mile, 7.90 is the best I have ever been on drag radials. Not sure if I will ever run 1/4 mile. Will changing the gears help me or hurt me and how bad will it slow my mid and top end down?
It will run through gears quicker and with less effort. But as far as knocking loads of time off your 1/4 mile, it aint gonna happen. The car will feel stronger though.
^^^ sorry buddy cant tell you an ET. Track was slick that day. I did trap 2.5 mph higher then I ever had before with the gears being the only change. I have since made other changes so it wouldn't be a direct comparison now.
