4.10 gears installation kit?
Anyone did a gear swap to 4.10s? What ALL did you buy with the gears? The complete gear installation kit costs around $123 and the gears cost $225.
Just wanna know if I need the whole installation kit or parts of it? Well which parts? Thanks
http://thunderracing.com/catalog/?ac...&vid=3&pcid=68
The thunder kit is nice. If you don't want to rebuild the rear end you can just buy a shim kit for cheap. I personally wouldn't reuse bearings. Opt for the master kit and refresh the whole rear end.
Does Thunder Racing have a Master Kit or where would you guys recommend I get a "refresh kit" to make my 10-bolt feel as "new" as possible & within spec?......
Btw, I have always used ratech's kits with good success so far.
I went with the Ratech deluxe kit as well. I didn't get the TR package, because I didn't feel like spending extra money on the cover. The Ratech kit comes with all bearings, shims, and seals that you will need for a complete gear install. The bearings are good quality too, mine came with Timken, Koyo, and Torrington. I'd get a Fel-pro gasket to replace the crappy cork one that comes with the kit though.
