Blew my 10 bolt at the Track with Full Bolt Ons and Street Tires, WTF?!
I took my car to firebird raceway tonight in Phoenix just for fun since one of my buddies was trying to get some new times on the spray in his Goat. I actually have never ran at the track before, only on the street . So I got a couple runs in, clicked off a 13.3 @109 with a shitty 2.2 60' which was decent for the 3800 DA. Not to mention my buddy's full bolt on LS2 goat on BFG drags ran a 13.6 @106 (off spray) so I figured it was good.
Well I go in for my last run and they just re-prepped the track. I Launch about 3K on my pretty much bald BFG Gforce Sport street tires and it starts wheel hopping. I let off right when it happened then hit it again, and it started wheel hopping really bad at the top of first and I tried to let off but heard a bang. I turned off in the return lane and I heard clunking as I went by, then when I went to park I heard another series of loud bangs. I ended up getting it towed back to my house.
My car has 120K on it and the mods are headers, ORY, cutout, LS6 intake, lid, Koni shocks/strano springs, Spec 3 clutch, and 275/40/17 street tires. I knew the 10 bolt was weak but I never though it was THAT weak!
What was wierd is I've launched my car a fair amount (even make 4 runs at the track tonight before breaking) and the car has NEVER wheel hopped. I know thats what killed the 10 bolt but again I've never seen my car of even my buddy's SS wheel hop that bad.
As far as the 10 bolt goes, luckily I didn't **** up the diff cover or lose an axle or anything. It definitely sounds like theres loose metal in the diff. I think I just need to get a new one.
So my thoughts:
-Are 10 bolts easy to swap out? Didn't look too bad
-What's a decent price for a 10 bolt?
-Ideally I'd like to buy one with 4.10s and be slightly strengthened. I have a set of richmond 4.10s in my garage but don't really wanna pay to install them if I can find a 10 bolt with them already.
-Don't have the cash to spend on a 9" or 12 bolt at the moment
-Anyone selling a 10 bolt with 4.10s near Phoenix?
Seriously though, blown 10 bolt on street tires and full boltons?!
So my thoughts:
Sorry to hear that man. Unfortunately, the ten bolt rear end developes quite a bit of wear and slack in them after 100k and they loosen up quite a bit. The age/wheel hop is definitely what caused your failure.
I wipe my *** with cnotes all day then.. LMAO..
first things first.. Take a good look at what is messed up.. then go from there. could just be the ring/pinion, maybe more.. who knows without crackin the cover.
Then you need to look at what your doing with the car, you said you dont take it to the track that often? Then why spend 2500 on a rear that you are not going to really use?
Once you have all that figured out, if you havent figured out what caused that nasty wheel hop, you need to, that put alot of stress on the rear, and if you stayed in it, that is almost 100 sure what caused your little issue here.
just my 2 cents... but you can make a 10 bolt hold up.. atleast until you start launchin at 5500rpm, with 12 psi DRs..
i was told by a former GM mechanic that the 10 bolt was only designed to handle 275 hp..wich is even more shady considering our motors came rated at atleast 325hp..some of us have just been a little luckier than others..
I have one that I cracked a few teeth off the torsen diff but the 4.10s, axles and housings still good. all youll need to do it replace it with a new diff and be good to go. I took it out a couple weeks ago and put my 9in in. i as still driving with the 10bolt but it would just click when i made a left turn. i sould sell it to ya cheap
I KNOW HOW YOU FEEL I WENT THREW 12 10 BOLTS, THEN I GOT SMART AND BOUGHT A MOSER 12 BOLT. tHE ONLY REASON I WENT THREW SO MANY IS AFTER I BROKE THE FIRST ONE I FOUND A SHOP THAT SAID THEY COULD BUILD ONE THAT WOULD HOLD. AFTER WARRANTIG THE 11 TH ONE HE FINALLY SAID NO MORE.
