what gears w/pt4400
Old 12-11-2003, 12:48 AM
98sspullin'em's Avatar
Default what gears w/pt4400
i have 3.23's now and was wondering if i needed 3.73's real soon for the converter?? and how long you think my rear end will last with that stall?? i have about 90k on it now... and does that T?A girdle help a lot?? i have heard but not real sure how good they really are!! thanks, dwayne
Old 12-11-2003, 06:54 AM
WILWAXU's Avatar
The 3.23's will work. 3.73 will help with better drivebility but they are not a "must".
Old 12-11-2003, 12:22 PM
will the times be a big difference or does it mostly just help it not be so loose??? im not to worried about that!!!
Old 12-11-2003, 02:16 PM
Jorday's Avatar
I have a PT and have stuck with the 3.23. I have read a lot of posts on this subject and most agree that the gains in the 1/4 by moving up to 3.73 from 3.23 with that converter will be minimal.
Old 12-12-2003, 08:02 AM
WILWAXU's Avatar
I only went with 3.73's when I bought my 12 bolt. Figure the gears made up for the extra 36lbs added by the new rear.
Old 12-16-2003, 11:07 PM
what about 4.10's? could i put them in my stock 10 bolt?and where would be the best place if i could?? and would 4.10's be worth all the trouble and high rpm's for a daily driver?? thanks, dwayne
Old 12-17-2003, 09:01 AM
WILWAXU's Avatar
4.10's will help with drivebility.. but will weaken the rear.
I suggest sticking with stock gears (smaller tires) till you can upgrade to a 12 bolt.
Old 12-17-2003, 09:05 AM
i dont even want to think about getting a rear end right now, much less a 12 bolt... thanks for the info... so i should stay with the 3.23's then?
Old 12-17-2003, 03:52 PM
WILWAXU's Avatar
Yeah, 3.23's with 26x10.5 ET Streets should do the trick
Old 12-18-2003, 01:44 AM
thanks for the help!!!
