4.10 or 4.11 gears for 12 bolt?
Old 11-29-2009, 07:14 PM
drain89's Avatar
Default 4.10 or 4.11 gears for 12 bolt?
Which ratio is stronger?
What brand makes a set that is strong but quiet enough for the street?
Old 11-30-2009, 08:28 PM
ss1
ss1's Avatar
I'm pretty sure 4.10 is the ratio used in a 10-bolt, and 4.11's are what you get in a 12-bolt. There is no choice between the two ratios as far as i've seen.
Old 11-30-2009, 08:46 PM
Wiktorek25's Avatar
i have motive 4.10's that i am still breaking in. and they make absolutely no noise. Noise all depends on how well they are set up and how hard you beat on them... pm me and ill give you me full rear end set up and who did it. i also have a 10 bolt
Old 11-30-2009, 08:58 PM
bore.me's Avatar
I believe a 4.11 gear is stronger than a 4.10 because it has 37 ring and 9 pinion teeth versus 41 ring and 10 pinion. Fewer teeth mean larger and stronger teeth.
Old 12-01-2009, 07:47 AM
ss1
ss1's Avatar
The 4.11 would definitely be stronger because a 12 bolt ring gear is 8.875" where a 10 bolt 4.10 is only a 7.5" ring gear.
Old 12-07-2009, 05:57 PM
drain89's Avatar
You sure? More splines on a shaft usually makes it stronger. Are gears different?
Old 12-07-2009, 05:58 PM
drain89's Avatar
You can get both for the 12 bolt. OEM's were 4.11, but the aftermarket offers 4.10
Old 12-08-2009, 02:29 PM
ss1
ss1's Avatar
Interesting...I believe you are correct! 41/10 or 37/9, it looks like Richmond sells 4.10's. I learned something new today
Old 12-11-2009, 06:52 AM
Restricted User
2001 Pewter WS6's Avatar
I have a brand new set of Yukon 4.11's for a 12 Bolt if you are interested. They are one of teh strongest and quietest gear available... PM me if you are interested...
Old 12-11-2009, 07:44 AM
In-Zane Moderator
ZONES89RS's Avatar
I have 4.30s, they are perfect for the drag.
Quick Reply: 4.10 or 4.11 gears for 12 bolt?
