what is good upgrade for stock rearend
First off, I have an a4 and heard it is not as hard on the rearend as a manual. How much power can the stock handle? What upgrades do you recommend for the 10 bolt, I don't have the funds to put a 12 bolt or 9 in back there. Any input would be nice.
Ill save you the search heres the link where i asked the same question. https://ls1tech.com/forums/gears-axl...g-10-bolt.html Pretty much the answer is save so thats what im doing. Hope it helps
I will add I am still on a 10 bolt ( have a 9 in ready on the ground ready to go in.)
my A4/10 bolt/ta cover with supports/detroit locker/3.73/ mos axels/welded tubes/mt drag radals/air bags/adjust ta on body mount/relocate brackets/adjust lca/MID- 11'
I suggest you try to find a 12 bolt 0r 9 ".
if you must try to keep the 10 bolt alive I suggest the TA Cover/ supports, mos axels, locker
Good luck, Johnny
I have been through seven 10bolts in my car... 3:42s were ok, 3:73s were like paper, 4:10s were the most durable... I know it doesn't make any sense other than if you are spinning you are not breaking. The only thing i would spend money on to strengthen up a stock rear is the t/a girdle.
