Is 2 drive shaft saftey loops neccesary?
Old 12-23-2003, 03:55 PM
LS1FIRE's Avatar
Default Is 2 drive shaft saftey loops neccesary?
Hello everyone.Is 2 drive shaft saftey loops better to get then one?1 for each U joint.And at what ET 1/4 is it neccesary to have a saftey loop? THANKS AND HAPPY HOLIDAYS
Old 12-23-2003, 04:02 PM
villain72's Avatar
your only required to have one no more than 3" from the center of the front u joint. and it's required any time your running slicks or 13.99 i'm not positive on the et
Old 12-23-2003, 05:11 PM
LS1FIRE's Avatar
Well i run 13.80 And it is not required.
Old 12-24-2003, 02:25 AM
villain72's Avatar
well maybe your track doesn't enforce it but yes it is required for 13.99 and quicker for nhra as stated in the rule book.
Old 12-24-2003, 11:28 AM
Camaroholic's Avatar
Actually, the measurement is no more than 6", and my local track lets cars run low 10's with no rollbar. So...
But anytime you're running a stock driveshaft with drag radials or greater, it's a good idea. I've seen the shafts pretzel, and I've seen loops protect the floor pans.
-Andrew (even my friends who don't have rollbars - run loops )
Old 12-24-2003, 02:35 PM
Mr Ed's Avatar
I don’t know whether there have been any recent changes but the cutoff used to be 12.99 on street tires and 13.99 if you are running slicks. For 1/8-mile tracks, it was 8.14 on street tires.
Years ago I saw a car snap the front u-joint. The drive shaft dropped down, dug into the pavement and catapulted the back of the car a couple of feet in the air. He was lucky the car didn’t hit the wall or even roll. Don’t take chances; get a loop even if your track doesn’t enforce the rule.
Old 12-24-2003, 11:31 PM
35th SS's Avatar
Wink
if I were you I would put a loop in there for safety reason especially if your dragracing.better safe than sorry.
Old 12-25-2003, 05:25 PM
LS1FIRE's Avatar
Thanks for all your replys.Should i get 2?1 in the front and 1 in the back?
Old 12-26-2003, 09:42 AM
villain72's Avatar
not necessary for front and rear, just in front they're worried about dropping the driveshaft and you going flying through the air.
Old 12-26-2003, 09:44 AM
villain72's Avatar
and your required one anytime you run slicks no matter what et.
