Repalcing gears on my car and I need HELP!!
So I have a few questions about putting 4.10's in my ta. Its a Torsen Diff so will I need the limited slip additive when I put the fluids fack in or not? And second I noticed my new ring gear (motive performace) is slightly thicker than my factory gear. Do I need to shim the entire carrier to the left to make up the difference or is my new pinion made to accomadate the thicker ring gear? And one more slightly technical question... How do the torsen differentials even work?
Just my thoughts:
second ? first, if your car came with a 3 seiars gear ( 3.23,3.42) the new ring will be ok , if you came with 2 seiars gear (2.73) then you have a problem, ring and pinion are a match, just install new gears with same shims to begain set up then check pattern and begain changing shims to obtain correct pattern.
>>> link: for answers on torsen dif. <<< http://www.torsen.com/general/general_faq.htm
also more info on setting up new gears
http://www.keliente.com/gears1.htm <<with this I had no problems
http://www.greenfries.info/rear_gear.htm
http://www.jawsgear.com/tech_kits.php
http://www.vernco.com/rearaxle5/index.htm
good luck Johnny
good luck Johnny
Not the leading edge of the block, the rearward side of it close to the tang that holds the mounting bolt. And good luck with a hand file you are gonna be there a while. I used a 4 1/2 grinder and a flap disc.
Everyone quotes the standard "Torsen units do not need additive". However, with 3 different gear sets my Torsen was a bit quieter with additive. Parking lot turns made odd groans that went away with additive.
The friction modifiers are for the clutches in Auburn style posi's. The torsen is all gears hence the picture I posted above. No clutches so no additive needed. Mine is dead silent and flawless in operation at @105k with cheap **** mineral oil 75/90 in it. Do what you want, Im just trying to help you become more educated
I didn't look at the rest.
1 Post
When I did my gear swap in my Firehawk (frist time doing it) I was like WTF it wont fit..I was like ahh **** all this time geting it set up and now the block or paddle whatever it is wont fit. First I was like drive it in..then I called my dad..he was like NOOO dont do that if I ever need toget them back out they wont and take achance of breaking the ring, 30seconds with the grinder took care of that. Fits fine..I had pictuers of how I did it but cant find um
Pinion depth measurement is a fiddly process and requires a lot of patience. Check my page for more.
The Torsen began life as the Gleason Torque Sensing differential. Gleason himself invented the concept but could not build it until he designed and built special gear hobbing machines that conventional gear cutting tools could not make. The internal gears of the Torsen employ quasi-worm gear geometries. Worm gears work using friction to cause locking when the worm turns the mated driven gear. Worms depend on friction to prevent being back-driven. Since Torsens are not meant to fully lock but instead to partially lock the differential, there is a lot of sliding going on. The friction modifier helps it slide. You can drive without it sure, but the service manual does recommend it.
