need to know what goes out in the 10 bolt
ok so i know nothing about gears and axles. but i want to know what all happens when they go out. i like to drive the car hard but not doing 4k launches or anything. i just need to know if it dose go wrong what am i mostlikely going to brake?
The 4th gen 10 bolt rear is waay to small for the power these cars possess. As a result, anything and everything can break on these rears. If you beef up one item, the next weakest link breaks. If your car is an automatic, you stand a better chance of the rear holding up. If you have a six speed, I recommend joining Triple AAA. Bob
1 Post
The housing twists..That eats up bearings, axles everything. I bought a brace kit to help, and was going to weld up the tubes, New everything.. Then I was like wow Im waisting money, I got smart and bought a new rearend..End of story...
so just going with a new rear end is the best choice? i will have to do some looking at prices then before i take the car to the track. any tips to keeping at alive?
will changing the fluid and just a good servis help any?
i found a rear end cover that says that it will lower the opp. temp, increase the fluid add additional strenth, and preloads the bearing caps. i have no clue what that means but if it would help to same some of the rear end i may be game for getting it. can someone explane that to me? tell me there thought on anything that bay be worth it info would be helpfull
http://www.exoticperformanceplus.com....html?item=148
Nothing will really help to do much to keep the little 10 bolt alive, it is just too small for the horsepower these cars produce, especially with a manual transmission. Bob
The cheapest and best way to go in my opinion is with this rear.
1 Post
I just ordred a spooled 12 bolt and mines a street car..nothing wrong with that just dont be a retard in the rain..
With a spool, Good street tires and wet roads youll be fine...
1 Post
Yes thats true, its becomes harder to turn but the more you drive one it gets easyer, they tend to "push" the front tires. Iv road in a few and its not too bad, just turn like youve got a 50ft trailer behind ya!!
Yeah but that is not a **** as a MWC rear end!!! I cant wait to get My MWC rear hopefully Ill be getting a phone call from Eric in about 3 weeks saying its ready. You get a lot more than just a rear for Eric rear end. You get torque arm, and ebrake brackets and brack line clips the only true bolt on f body rear in my opion. Last time i check the moser axle housing doesnt come with any of that stuff.
what dose spool mean? i dont understand why that would make slow cornering harder. this is a daily driver for me and i want the car to still be fun on long trips say form MN out to ND or SD up in the mountons and what not
my 10 bolt just **** on me yesturday. split the case in half. im suprised it lasted as long as it did. it sucks now i gotta find a way to get the money for a moser unit. anyone selling a used one!?!?
