10 bolt rebuild question
Old 04-18-2010, 08:31 PM
natejk's Avatar
Default 10 bolt rebuild question
i am rebuilding my stock 10-bolt soon has anybody heard of a 85-11003 Ratech Smart Sleeve (Pinion Spacer/Crush Collar) GM 7.5" 10 Bolt
Old 04-20-2010, 08:18 PM
natejk's Avatar
anyone?
Old 04-22-2010, 05:36 AM
Mark98SS's Avatar
Never heard of it, I'm no expert on 7.5 rears but I did just finish a rebuild on the one in my 2001 Z28 street car. I used a NAPA crush collar, was a beeeotch to get "crushed" must be about 300 ft-lbs to turn the nut.
Old 04-22-2010, 10:30 AM
stburgpete's Avatar
Are you talking about a speedi sleeve?
Old 04-22-2010, 11:17 AM
Marc 85Z28's Avatar
AKA the solid pinion spacer. Lots of people here use it. What about it?
Old 04-22-2010, 12:14 PM
stburgpete's Avatar
Just put one on yesterday they work great. I have no leaks so far.
Old 04-22-2010, 12:33 PM
stburgpete's Avatar
and easy to install
Old 04-23-2010, 08:59 AM
natejk's Avatar
ok good info im rebuilding it as soon as thunder racing decides they want to ship my parts hopefuly next week i went ahead and ordered the smart sleeve with the kit is there any difference in installation besides that its easier?
Old 04-23-2010, 09:08 AM
natejk's Avatar
Current Crush Sleeve design:
Purpose of the item is to maintain pressure between two tapered roller bearings located on a common shaft to prevent position change of the bearings and fastener during operation.
During installation the bulge will compress as the bearing center distance is decreased thus applying thrust pressure to both bearings and fastener.
The current industry design has three bending or compression points of the bulge area.
Installation characteristics are an initial high thrust pressure for approximately the first .010 of length change of the spacer then thrust pressure drops approximately 20%.
Typical required fastener torque to compress the spacer is approximately 300-400 ft. lbs.
The usable compression distance is .040-.060 in length.
Cycle duty is poor.
New Patent Pending Smart Sleeve design:
The bulge area is restricted to two areas with the majority of the deformation taking place on the flat of the bulge. (B)
Installation characteristics are a consistent thrust pressure for the entire length change of the spacer.
Typical required fastener torque to compress the spacer is approximately half of the current design. (130-150 ft.lbs.)
The usable compression distance is .095 in length.
Cycle duty is better than a solid spacer and shim pack.
Old 04-23-2010, 09:50 PM
Mark98SS's Avatar
....Typical required fastener torque to compress the spacer is approximately 300-400 ft. lbs.
Felt like it LOL
Old 04-23-2010, 10:39 PM
natejk's Avatar
I bet haha
Quick Reply: 10 bolt rebuild question
