Moser Prices at Brute Speed - Includes Shipping!
#81
Moser rears for many domestic vehicles have been added to the website, you can find them at this link. http://shop.brutespeed.com/Moser-Rea...icles_c145.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#82
Moser 60 rear has been added to the website. Bob
__________________
#83
I have added a new option to the rears on my website. You can save $140.00 if you want to set up the gears yourself. This is for those who have experience in setting up gearsets or know someone who is. Bob
__________________
#84
Hey Bob,
I have a Moser 9" True Trac 3.89 gears w/31 spline axles, BMR drag pac torque arm, and BMR lower control arms. I bought it from you about 2 years ago and has about 6000 miles on it. My car is a 2000 SS M6, bolt-ons with 355 rwhp. I have had no problems so far but I have not been to the track with it. I do have MT E.T. street radials on and have done some hard launches on the street without any issues. Am I looking for trouble if I take it to the track? I have not seen to many good thing on here about the True Trac but when I bought it, the True Trac was the hottest thing going. Also if I did upgrade would a Wavetrac with 35 spline axles fit in my housing? And if so at what cost?
Thanks
Dave
Thanks
Dave
#85
Hey Bob,
Thanks
Dave
Thanks
Dave
Hi Dave, normally when people have problems with the Truetrac's, it is long before the mileage you have on yours. Since you have also done hard street launches with ET Street Radials, I'd say your chances are pretty good that you won't have problems at the dragstrip.
You probably have a 3.062 O.D. carrier bearing size case, the Wavetrac requires the larger 3.250 O.D. carrier bearing case. A spool would be your best bet if you do take out the Truetrac, although I don't think that will happen. Thanks. Bob
__________________
#86
Bob,
I looked at my invoice on my Moser rear and it says it is a Trac Loc w/ 3.89 Pro gears and 31 spline axles. Is a Trac Loc different from a Tru Trac? I purchased it in Sept. '07 and had 50,000 miles on my car, I now have 64,000 miles. No track time but quite a bit of street abuse with many violant 2nd gear hits. It feels very solid and I am confident that it will hold up. What is the difference between a True Trac and Trac Loc?
Thanks again
Dave
Thanks again
Dave
#87
Bob,
Thanks again
Dave
Thanks again
Dave
__________________
#88
Moser Adjustable Chromoly Transmission Mounted Torque Arms, Adjustable Chromoly Lower Control Arms and Adjustable Chromoly Panhard Rods have been added as options to the Moser rears on my website. Bob
__________________
#89
__________________
#90
Order a Moser rear (Tuesday) today, and it will ship out this week to you! Bob
__________________
#91
http://shop.brutespeed.com/Brute-Spe...ed-Formula.htm
Brute Speed's Formula with Moser rear featured in October issue of GM High-Tech. We have a Moser 12 bolt in this Formula. Bob
__________________
#94
Cool, there is a lot of good info in this issue. There is a nice article on RPM Transmissions 2007 Z06 LS7 stock block running in the 9's in the 1/4, with a ProCharger D-1SC. Bob
__________________
#95
$65.00 per axle to respline the axles, $125.00 to shorten the housing.
Thanks. Bob
Thanks. Bob
__________________
#97
Awesome, thanks! Your new Moser rear will be leaving Wednesday or Thursday (short week with Holiday) to head to you! Thanks again! Bob
__________________
#99
Yes it will, thanks. Bob
__________________
#100
[IMG]1992 - 2002 Camaro and Firebird (F Body)
Moser 9 Inch Rearend with Trac-Loc Limited Slip, Locker, Wavetrac and Spool options
$2450.00 shipped with Trac-Loc, 28 or 31 spline axles
$2500.00 shipped with Locker, 35 spline axles
$2910.00 shipped with Wavetrac, 35 spline axles
$2300.00 shipped with Spool, 35 spline axles
Options:
3 channel $175.00
4 channel without reluctor rings $100.00
4 channel with reluctor rings $175.00
Drain plug $35.00
Drain and larger fill plugs $70.00
Lower control arm relocation brackets with three extra sets of holes $0.00 - No extra charge
Sway bar brackets welded to rear for either stock sway bar or for the BMR Xtreme anti roll bar $50.00
Rear powdercoated your choice of color $200.00
Backbrace $140.00
Aluminum performance case instead of nodular iron $155.00
40 Spline Axle Upgrade for Spool $85.00
Extreme Axles - Star Flanged and Gun Drilled $140.00 - Not recommended for street use
PST 3.5" alum 1000 hp rated driveshaft equipped with front yoke and two 1350 u joints $400.00
Includes 9 in. Center Section, Housing, M/E Custom Alloy Axles, wheel bearings, wheel studs, retainer plates, Pro Street gears, 1350 series pinion yoke, torque arm bracket and nodular iron case. It basically includes everything you need, ready to bolt-on. You will need a U-Joint, gear oil, vacuum line for the breather and two 3.00 inch exhaust clamp u bolts unless you order the rear with the sway bar brackets.
Options:
3 channel $175.00
Drain plug $35.00
Backbrace $140.00
can you go over why you would need these options? I am trying to learn what I would need and/or want when it comes to the rearend of the car as I will be saving up to purchase one
and with these what size would I need and I am just lost when you mentioned the vacuum line
