3.90's or 4.10's
Old 05-09-2010, 03:09 PM
BruceBufferTA's Avatar
Default 3.90's or 4.10's
I'm considering a gear change for my 02 TA M6 (Non-DD) and I'm curious what opinions you all have on which gears I should go with...3.90's or 4.10's? Stock 10 bolt fyi. I will not be drag racing the car, stricktly around town cruiser.
Old 05-09-2010, 03:29 PM
bigj2717's Avatar
I went withh 4.10s and I lvoe them. Its not bad at all to drive everyday just makes it alot more fun
Old 05-09-2010, 03:55 PM
corvet786c's Avatar
I heard the 3.90's are a lil stronger than the 4:10's. with almost the same performance, better gas mileage.
Old 05-10-2010, 09:51 AM
Anyone else??
Old 05-10-2010, 10:00 AM
ahhwataday's Avatar
You gonna change your tire size in the rear?
I have 4.10 and first gear is way to short. Ima swap to 3.90's soon
Old 05-10-2010, 10:16 AM
Nope. Keeping 275/40/17 all around.
Old 05-10-2010, 02:54 PM
ahhwataday's Avatar
Street car, 6 speed id say run 3.90's
I think most ppl dont get these bc they are unfamiliar with this ratio, unlike the 3.73 and 4.10's
Old 05-10-2010, 02:59 PM
Jawsgear's Avatar
You would be best suited for the 3.90.
Jeff
Old 05-10-2010, 04:31 PM
Thanks you guys for the help and info
Old 05-11-2010, 06:48 AM
FST SS's Avatar
I run 3.89's, pretty close to 3.90's and they are just rigjt for my power level.
Old 05-11-2010, 08:07 AM
01ssreda4's Avatar
I say 4.10s all day
Old 05-13-2010, 10:30 PM
darrell hoagland's Avatar
im going with 4:30 gears,
Old 05-14-2010, 10:31 AM
Midnight02's Avatar
I went with the 3.90's and am glad I made that decision. Makes driving on the streets more fun however it doesn't kill gas mileage and I still have plenty of gear to work with.
Old 05-14-2010, 11:11 PM
*02WS6TURK*'s Avatar
There's not that big of difference between 3.90's and 4.10's. About 5%. Roughly 100 RPM difference. If you go with 3.90's go with the Motive and if you decide on 4.10's go with OEM GM Gears.
Old 05-17-2010, 08:51 PM
Randy WS6's Avatar
Ive run both gears and the 4:10 is the best for cruising you can pull out in second gear from a dead stop ,but you will blow the tire off if you decide to play, The 3:90 gear is a good highway gear and not so harsh on the tires ,but a step above the 3:73's. And the 3:90's are a little stonger , because of the pinion size .
