9" for $50
Old 05-21-2010, 01:31 PM
DIRTY_WS6's Avatar
Post 9" for $50
I just picked up a 9" out of an 80s FORD, got it from a guy i work with for $50...i was going to modify it to put into my ws6? anyone have any tips or help me with where i should start? or did i waste my money! thanks in advance
Old 05-21-2010, 01:41 PM
Outlaw72's Avatar
You didn't waste your money. Take the 9 inch to a chassis guy along with a bare 10bolt and let them model it. Just take it to a good chassis guy.
Old 05-21-2010, 01:52 PM
DIRTY_WS6's Avatar
Post
so you think when its all said and done i will have saved lots of money? thats what im hoping!!
Old 05-21-2010, 03:59 PM
SLP4CamaroSS's Avatar
dont know until you get a quote on the fab rearend
Old 05-21-2010, 07:55 PM
DIRTY_WS6's Avatar
Post
well i found this place online called quick performance...anyone ever heard of them? they sell the 9" housing for just under $1k and it comes with everything but the center section... what you guys think of this place? seems legit? bc then all i would have to do is put the center section from the 9" i already have in the housing i would buy from quick performance?
Old 05-21-2010, 08:14 PM
DIRTY_WS6's Avatar
Smile
9" GM F-Body Bolt-In Housing
$995 Complete w/ Axles, Axle Bearings, Studs, Retainers, & Tubular Torque Arm Bracket
Fits: 82 & Up Chevrolet Camaro & Pontiac Firebird
* Comes Standard w/ Big Ford (new-style) Housing Ends
* GM Flush Mount Ends Available for No Additional Charge
(Allows use of factory brakes on 93 & Up)
* Custom Made To Order - Any Length
* Comes Standard w/ 1/4" DOM Tubing
* Comes Standard w/ Drain & Fill Plug Installed
* Housing Weight w/ T-Arm Bracket = 76lbs.
* If the car has been raised or lowered 2" from factory an adjustable panhard bar is required
does all of this info look good to you guys?...anything i should be concerned about before i buy it?
Old 05-21-2010, 10:54 PM
SS SLP2's Avatar
I had good dealings with Quick,
be sure you order the correct axle splines to fit your old ford carrier
Johnny
Old 05-22-2010, 05:32 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
http://shop.brutespeed.com/Moser-9-I...-and-Axles.htm
Here is the Moser housing and axle package, which starts at $1050.00 shipped. This combination is shipped out just two days after the order is received. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 05-22-2010, 07:19 AM
SS SLP2's Avatar
Yep I had great fast service from Bob when he was with EPP, am sure his new co . is even better
Johnny
Old 05-22-2010, 08:33 PM
DIRTY_WS6's Avatar
Post
do you guys really think a 9" in necessary? ive heard A4 10 bolts hold up to more power than a manual? heads/cam/intake is what my final plans are!!!
Old 05-23-2010, 05:13 PM
Ponch95's Avatar
F-body 10 Bolts are like Forrest Gumps Chocolate...you never know what your going to get! I would say normally anytime you go over 425+ HP your living on borrowed time, however I have seen people in excess of 600+ still running on their 10 bolt.
If you do want to use this 9" of your's, my brother went this route and had the axles cut to proper length and then placed his 10 Bolt on a table...tack welded the Diff by the brackets onto the table..then he cut off the brackets..removed the 10 Bolt, placed the 9" onto the brackets on the table and then rewelded the 9" to the brackets.
Hope this helps.
Old 05-24-2010, 05:22 AM
LS1Tech Sponsor
Johnny
Thanks Johnny, I appreciate it. Bob
__________________
Old 05-25-2010, 09:50 AM
TDP
TDP's Avatar
I would spend the ~$1000 on the 9" that is made to fit. That's a good fair price. I don't think it would be worth it to modify an old 9" to fit you f-body, even if you got it for free.
Old 05-25-2010, 02:49 PM
Outlaw72's Avatar
I don't know about lots of money but I'm sure it could be done for alot less if you are on a budget. There are people out there that can fab the housing and get you set up with axles. Will it cost less than an axle/housing package....more than likely. But how much less is something I do not know. I assumed you were on a tight budget and with a little knowledge and research, you can get it done for less. It makes sense to buy a housing/axle package for $1050 if you have the extra dough laying around. It takes the legwork and research out of it in the case of being on a budget and you get everything you need except for a 3rd member.
Old 05-28-2010, 11:16 AM
k5383's Avatar
This might be a stupid question but how does the brakes work?
I built a 9" for my buddies mud truck, so I'm familiar with the plates that the axles and in his case the drum backing plates bolted to. Are the factory 10 bolt brake brackets the same bolt spacing? Thus allowing the use of factory parts? If so how does the E-brake work? Same thing, factory disc plate will bolt to the 9" housing?
Old 05-28-2010, 11:36 AM
KC&97TA's Avatar
Johnny
+2 on Bob, great and fast service.
to the OP, pull the center section, find out the splines of the carrier and order the axle houseing package for $1000, you'll be so freaking happy you did in the long run.
I have a 9" in my A4 2000 SS, it's piece of mind that I'll never blow it apart. Your $50 spend on the 9" just saved you about $1000 on the carrier set up as long you can live with the gears that are installed in it.
Old 05-31-2010, 08:14 PM
welldonecj7's Avatar
And if you do this you can prob still list the $50 9" on craigslist without center section and get at least $50 for it.
