Jaws Gear & Moser Rearends & Parts
Ford 9” – Complete Differential Assembly for F-Body Cars from $2199.00 Shipped
- ABS Setup: None, 3 Channel, 4 Channel
- Axle Spline: 28,31,35,40
- Back Brace: Yes, No
- Carrier Type: Full Spool, Truetrac, Detroit Locker, Wavetrac
- Drain Plug: Yes
- Dropout Case: Nodular Street, Nodular HP, Aluminum Through Bolt
- Finish: Raw
- Gear Ratio: Choice
- Pinion Support: Daytona
- Pinion Yoke: 1310, 1350
- Stud Size: Choice
- Stud Type: Press In, Screw in Stud
- Sway Bar Mounts: Yes, No
Note: All options listed above may have an additional cost associated. Please confirm pricing at www.jawsgear.com or give us a call.
Ford 9” – Housing & Axle Package for F-Body Cars from $1080.00 Shipped
- Drain Plug: Yes
- Finish: Raw
- Stud Size: Choice
GM 12 Bolt – Complete Differential Assembly for F-Body Cars from $1999.00 Shipped
- Axle Spline: 30, 33, 35
- Bolt Circle: Choice
- Carrier Type: Full Spool, Eaton, Truetrac, Detroit Locker, Wavetrac
- Differential Cover: Chrome, TA Girdle
- Finish: Raw, Powder Coated
- LCA Brackets: Yes, No
- Stud Size: Choice
- Stud Type: Press or Screw In Stud
- Type of Rear End: GM "F" Body w/Torque Arm Bracket
We carry a full line of differential replacement parts for your stock differentials from Ring and Pinions, Positractions, Lockers, Rebuild Kits, Axle Bearings and Seals, Axle Shafts, Pinion Seals, Pinion Yokes, Spider Gears, Differential Covers, right down to the Oil and Positraction Additive. Let us know if we can be of any help in your differential needs.
In addition to differential parts we can produce custom driveshafts for many applications. Call for details.
Jeff
- Drain Plug: Yes
- Finish: Raw
- Stud Size: Choice
- Drain Plug: Yes
- Finish: Raw
- Stud Size: Choice
- Stud Size: Choice
Jeff
looks like I'll be in the market here shortly for a complette rebuild for a Moser 12blt, seals, bearings and all the rest minus gears at this point. What would I be looking at $$$ wise.
Jeff
