Help Noisy Moser!!!
Help Noisy Moser!!!
I got a 12 bolt Moser with 4:10 gears, I believe they are Richmond Gears, because It came with Richmond Stickers! It is pretty noisy on the freeway, how can I quite her down? Also what fluid are you guys running, and what posi additive? Thanks Guys!
Find a good quality shop that can do it for you. A friend of mine here just had his done by a mechanic from a VERY reputable shop on the side and he paid $150. he said his is WAAAAYYYY better now. I need to have mine done cause my Moser screams like a Biyatch
well by now you need a new set of gears since the pattern has been set now.if you do want them quiet have a good shop reinstall them and set them up.
i had the same problem with my Moser, they gave me a lame *** excuse and wanted me to take the rear back out and send it to them, yeah right. i knew it was the lash so i broke down and bought a new set and havent had a problem since.
pretty much as soon as it starts to whine its done, the wear pattern has been set.
i know it sucks ***. Moser put up a disclaimer on there website about gear noise and how they set the ponion with more Toe so longevity.. i have since worked on cars that turn high 6's in the 1/4 and pulling 1.06 60ft and those rears dont sound anywhere what my moser sounded like...
I had an expert dial in my Richmond ring and pinion. It's as silent as stock. I also have a Strange on order because I am hoping that they set up the ring and pinion better than Moser.
Historically, I should be fine. Thanks to all who posted about their loud Moser, you may have saved me much anguish.
