Choices of differentials in 12 bolt
I'm looking into getting a Moser 12 bolt for my '02 T/A and I need some input on which differential is best for my application. I'm making around 500whp, the car is a street/strip. I put around 6,000 miles on the car a year, but it also sees the track about twice a year. I've been told Auburns are strong and is one I should look into, but I've also heard that the clutches wear out on them fairly quick, and thats not something I want to deal with. I like the Zexel Torsen in my stock 10 bolt, but I hear aftermarket versions of torsen differentials are loud and not as strong.
Let me know your input, thanks!
You have the option of the Truetrac which is similar in design to the Zexel but much stronger or the Eaton Positraction which you can upgrade if you throw more power at the car. Either one would be a good choice for your application out of the box.
Jeff
Jeff
LS1Tech Sponsor
Here are my prices on the Moser nine inch rears that are designed for these cars. http://shop.brutespeed.com/82-02-F-B...ar-Ends_c5.htm
Do you think you'll be staying at the 500 rwhp mark, or will you be adding more power in the future? The Wavetrac is more expensive but is what I would go with if you think you might up the power level at some future date. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
nah im looking for 4.11's, thanks though valkyn.
and thanks for the info bob, i read through your website and may go with the 9" if the 12 bolt does have problems with hard launches on slicks when making 500whp. I most likely will stick around 500whp, i dont see myself spraying or going with a power adder. The truetrac sounds like what I might want to go with. Like I said I love the zexel torsen differential. Its quiet and drives well. So I guess the aftermarket differential I'd want to go with is the one that is closest to the Zexel Torsen, yet strong enough to hold a launch with 500wrp and slicks.
