is the rear diff cover thicker question
i was told to get a trans am diff cover because it was thicker than my z28 cover. he told me this because im putting in 410s and it would help support when the gears "flexed" when u stepped on it. does this hold true??
a thicker cover will not help ring gear flex. I assume they are suggesting a TA Girdle Cover as it supports the main caps and keeps the ring gear from deflecting the caps.
Jeff
Jeff
Kleeborp the Moderator™
In this case, TA does not stand for Trans Am - it is a company that makes aluminum support covers to replace the stamped factory piece. The jury is out on this one from what I've read...on a 10-bolt, it is like putting a band-aid on a gunshot wound. My 12-bolt came with one, and all it does is leak
Here is a link to our website..
http://www.jawsgear.com/Differential...duct_info.html
Bandaid would depend on the amount of abuse the car gets IMO. I have installed thousands of these covers on various applications and NEVER had one leak. Install error maybe? We also scuff the surface so it gives the sealant something to stick too.
Jeff
Jeff
Jeff
Jeff
Which, in the "oh, by the way" category: what's the status of my order?
