modifying a 'torsen' paddle-pics
Old 07-29-2010, 05:22 PM
FirstYrLS1Z's Avatar
Default modifying a 'torsen' paddle-pics
took a 3series torsen with Richmond 3series 4.10s'
pic shows insertion interference
marked the paddle where the interference starts and took it to the grinding wheel. ground,test,more grinding,test,more grinding till it was able to slip in
finished and able to go in showing side view of amount of material needed to be removed
4.56s' would require more material removal because of its' smaller diameter pinion which results in 'taller' teeth on the ring gear
Attached Thumbnails modifying a 'torsen' paddle-pics-dscn1671-c-s.jpg   modifying a 'torsen' paddle-pics-dscn1674-r-c-s.jpg   modifying a 'torsen' paddle-pics-dscn1673-c-s.jpg
Old 07-29-2010, 10:56 PM
TooFast3800's Avatar
I'm a noob, what's the paddle thing for? And why is it done to the Torsen unit?
Old 07-30-2010, 11:24 PM
joecar's Avatar
It keeps the axle shafts positioned outward so the c clips don't fall off.
Quick Reply: modifying a 'torsen' paddle-pics
