Some fancy new 9" parts - pics
Finally got here, if anyone was curious about what the star flanged and gun drilled axles look like here they are. Also the new cast moser torque arm mount is like a zillion times nicer then that old welded up mess they used to use. Still some heavy stuff though but I dont think my rotating weight will be too bad
Nice!
Any idea if that torque arm mount sits the same as the old welded up mess they use to run?
PSJ
Has the old welded up mess they use to run
PSJ
I have the same rear in my car .. if you get a chance before the install can you please weigh everything. I did not have a chance to do it at the time of install Did you go with the 33 or 35 spline axles ???
Weighed the parts a little while ago..
Bare housing = 69lbs
axles with backing plates/caliper mounts and bearings (no parking brake shoes) = 49lbs
aluminum center section w/spool = 56lbs
torque arm mount = 14lbs
Looks like 188lbs total..
Going to install the stuff now
