how to tell if rear end axle bearings are shot?
i get a weird vibration now when going down the highway and doing a lane change to the left or a sweeping left turn. one theory was maybe the axle bearings are worn? creates play? how can one tell? or am I way off base?
Does this happen during acceleration, coasting or cruising?
... Due to the very few details listed in the post I am going to say I had similar problem after finding and correcting excessive backlash the situation improved but did not go away completely. Looking for more solutions.
See if this will help:
http://dodgeram.org/tech/repair/axle...sis/page1.html
Location: Oklahoma City, OK/North Long Beach/Paramount, CA
i have the same problem but it only grinds/whines from 3rd gear and up as i accelerate. also ive been told my tranny needs a rebuild, and also i have a leak from my driver side axle and a leak from my ring and pinion..... =/
Moser 12 bolt
my rear wheel started making a noise then the right wheel was hot and smoking. thought the bearing might have seized so I parked it then drove a few hours later and the noise was gone/wheel was not longer smoking???
Early indications of a bad bearing? Ebrake problem?
