Where can I get tools to rebuild 10 bolt?
I already have gears and install kit. Where can I rent bearing puller, dial indicator, inch lb torque wrench, things to install the bearings, and anything else I need. I thought I would be able to rent this stuff from autozone or O'Reillys, but it seems like they don't have any of it. And if I have to buy the stuff where is the best place to buy it.
You need a dial indicator and base. HF $25 on sale.
Beam style inch/pound torque wrench. Search ebay. I got mine for about $60.
http://cgi.ebay.com/ebaymotors/KD-29...motiveQ5fTools
Bearing seperator for the inner pinion bearing:
http://cgi.ebay.com/LARGE-MECHANICS-...item3a52942bd5
This is for the wheel bearings:
http://cgi.ebay.com/ebaymotors/Neiko...item564050d389
Ok, thanks I got everything figured out except how to put the bearings back on. I figured I would just use some pipe like in the pic above and hammer them back on. So where would I get some pipe like that?
I had a local machine shop remove the pinion bearing for me and then reinstall it later. Really cool guys, they answered a lot of questions I had. They even let me borrow an oversized bearing to do a mock up with my pinion shim. And they let me borrow a big tool to hold the pinion yoke while I crushed the collar.
Buy a cheap press. Thats what I did. I got a 12 ton for $130 brand new. Have used it a ton of times since and rebuilt at least half a dozen 10 bolts with it.
