quick perfromance 9" install is getting started!
So far im going to have to drill the holes out where the shocks bolt up and the PHB bushings look like im going to have to beat them in!
Narrowed 2.5", strange center, 35 spline CM spool, moser 35 spline axles,$2,100 shipped. ill keep u updated! So far its being a bitch. Sucks installing a rear end buy your self!
So far the bad
1. PHB wont go in even with beating it
2. I have to find a drill big enough to drill hole bigger for shocks. im can hold a drill bit that big.
i dont have one. i have a drill bit the same side i could use to take some off. but i dont have a drill big enough to use it lmao. its a easy fit if i had the drill
OMG u got to be kidding me! not only can i not get the panhard bar on with beating the crap out of it i notice that once i do get it in the bolt holes are to small WTF!!! So now i got to grind on the panhard bar to make it fit because its to wide i have to drill bigger shock and panhard bolt holes!!! Direct bolt in my ***!!!
if i had the tools it wouldnt be bad. All they need to do is drill hole a touch bigger and where the PHB slides in it needs to be a little wider. SO FAR THATS ALL lol
amazing how easy installing a rear end when the bolts holes are drilled to
the right size and other stuff! Spent over 2 hours hamming and more to
get the rear housing it yesterday and no go. Well today did some grinding and some
drilling at the shop then came home and it was in in 10 mins of work lmao!
well now cant get backing plats bolts to work. Stock or the ones they sent Here it is so far
BAD
1. PHB wont go in even with beating it so will have to grind
2. I had to drill hole bigger for shocks.
3. I had to drill bieer hole for PHB
4. I have to find a way to get backing plates on stick or ones with kit wont work.
BAD
Because this is a few hundred cheaper and a good bit lighter. Its all minor stuff i just dont have the tools here i jist moved. If i did it may take 15 mins of work total. Other people have not had these problems.
It was easy i just had to grind one side of the bolt head flat or u spend 15$ for some t bolts. Its worth is for the money and weight saved. I mean a total of 15 mins of work on it.
Dont forget to get lca brackets welded on like i did :-( i think they only charge like 30-50$. It comes with big fill hole and a drain. Other u have to pay extra to get.
