whats the length of the stock driveshaft?
Old 02-09-2004, 12:59 PM
smokinHawk's Avatar
Default whats the length of the stock driveshaft?
this is the same length that ill need for a m6 to a 12 bolt strange right.
going with a steel shaft and need the dims as i dont have them handly
does anyone know?
Old 02-11-2004, 06:36 AM
smokinHawk's Avatar
up ttt
Old 02-11-2004, 08:14 AM
M6HTZ's Avatar
I have a similar question.. Do you need a new ds if you get a Moser 9" or can you use the standard length ds?
Old 02-11-2004, 02:58 PM
smokinHawk's Avatar
I know on the moser it requires a different shaft length, think it is shorter.
Old 02-11-2004, 06:32 PM
DaveSchott's Avatar
There is enough variation from car to car that it's best for you to have trans & rear installed and to measure it. Denny's insisted I measure and when i got the d/s it was a perfect fit. that said, i might have my dimesnion sheet around yet, I'll take a look for it.
Old 02-11-2004, 06:38 PM
DaveSchott's Avatar
OK, found it. I used diagram "B" on denny's site (dennysdriveshaft.com) for my measurements. length #6 from trans case to flat surface on pinion yoke.
mine measured out at 44" exactly. YMMV. M6 & Strange.
Old 02-12-2004, 08:20 AM
smokinHawk's Avatar
ok thanks, reason i said stock driveshaft was i put on my stock shaft and it fit were it should, cept it didnt have the 1350 pinion.
Old 02-12-2004, 04:09 PM
DaveSchott's Avatar
Oh. Doni't know if the 1350 yoke is dimensionally same as 1310...that could be an issue.
mine has 1350's at both ends.
Old 02-13-2004, 06:46 AM
smokinHawk's Avatar
maybe ill wait till i get my torque arm then so i can measure it, but that will be about 2 weeks.
Old 02-13-2004, 01:34 PM
Fulton 1's Avatar
Exactly the same dimension I go with M6 and Strange using the Denny's diagram B. Length ended up same as stock.
While I was waiting for my driveshaft to arrive I used the stock driveshaft with the Strange and it fit perfectly. I also took some pics of the OEM side by side with a Denny's Nitrous Ready shaft and a Denny's MMC (3.5" Aluminum) shaft and can email them if anyone's interested.
Old 02-18-2004, 09:02 AM
smokinHawk's Avatar
from pinion to pinion the stock driveshaft measured 40-7/8" long
