My latest mods finally completed: S60, CM-DS, Spohn T/A, Drag Sway, LCA’s, PHBR
Old 06-07-2011, 03:00 PM
BrianSF-GA's Avatar
Default My latest mods finally completed: S60, CM-DS, Spohn T/A, Drag Sway, LCA’s, PHBR
My S60 delivered & unpacked.
-Strange Engineering PRSF10
-35-spline Pro Race axles
-axles drilled & tapped for 1/2”x4.5”, 4.75” & 5/8”x4.75” studs
-35-spline spool
-1350 series pinion yoke
-4.10 ring and pinion
-2”x1/2” wheel studs
-BMR adjustable (3-hole) lower control arm brackets (welded)
-Strange Engineering 3" Chrome-moly driveshaft with transmission yoke and 1350 U-joints
Thank you Carl at Central Racing Parts (CRP).
Spohn drag sway bar, lower control arms, chassis mounted torque arm & panhard bar rod. All rod-ends.
Thank you Steve at Hawks Camaro for price matching a killer deal & quick shipping.
Cleaned & etched with POR-15’s Marine-Clean & Metal-Ready.
Coated with POR-15.
Out with the old 10-bolt.
In with the new S60.
S60 completed.
Sphon drag sway bar & panhard bar rod.
Spohn chassis mounted torque arm & lower control arms.
Notice the drag sway bar has offsets to clear the shocks like the BMR’s and UMI’s. I was planning on the “straight” style Spohn drag bar which others have been able to fit to the “stock” sway bar mounts. With this “new” style, I ended up having to cut off the “stock” sway bar mounts and used the Spohn mounts. There is plenty of clearance from the shocks though. If you plan to run a drag sway bar, remember to order a rear without the “stock” sway bar mounts as I did not.
After the Strange recommended ring and pinion break-in, I realized I would hate the rod-ended suspension in a predominantly street driven car. The rod-ended components have made the rear end sound like it is ready to literally fall out. If this was predominantly a street car, I would not be running rod ends. At slow speed turns, the spool actually accentuates the noise of the rod-ended components. Since this is predominantly a drag car, I look forward to “no binding performance” of the rod-ended components.
See my thread for my latest appearance mods: https://ls1tech.com/forums/appearanc...l#post15014460
Old 06-07-2011, 05:29 PM
raymond mckinney's Avatar
Looks very nice!
Old 06-07-2011, 05:50 PM
ramairetransam's Avatar
very nice , i never noticed until now , no brake lines on the rear end . I wonder if any of the aftermarkets come with lines ran .
Old 06-07-2011, 09:06 PM
camaroz28lt1at's Avatar
You can see the brake lines in the last two pics. Just reuse your stock ones.
Old 06-07-2011, 09:35 PM
BrianSF-GA's Avatar
Originally Posted by raymond mckinney
Looks very nice!
thanks ... !
Old 06-07-2011, 09:41 PM
BrianSF-GA's Avatar
Thanks ... Actually, I never disconnected my stock brake lines. The S60 is larger than the 10-bolt so the brake lines sit on the rear in a different location and I could not use the brake line tabs Strange provided. I was able to bolt the brake line tee bracket onto the S60 in the provided tapped hole so the brake lines are secure. Keep in mind that this was a 3-channel rear ... single line from the ABS module splitting to two lines at the rear. Since I am running a spool, the ABS is deactivated and I will add an ABS delete kit with a line lock install.
Old 06-07-2011, 09:43 PM
BrianSF-GA's Avatar
Also note that while my stock springs were out I did perform the "hose mod" so the rear would not be so high with the larger axle tubes on the S60.
Old 06-09-2011, 12:52 PM
Formally Simplɘ Jack
BoricuaHec01's Avatar
That's real sick dude.
Old 06-09-2011, 02:02 PM
BrianSF-GA's Avatar
Thanks ... it has been a busy few months and I wanted to share everything I got done. Since there are two topics, I made two posts. Thanks for commenting on both.
Old 06-09-2011, 11:59 PM
lethal bird's Avatar
Ballen.... Now go get someone to video you launching the **** out of it when you get it broken in.
Old 06-10-2011, 07:41 AM
BrianSF-GA's Avatar
that's the plan ... at least when I find some RaceStars and slicks. I may do some 1/8 mile passes on the street Nitto's to get a base line.
Quick Reply: My latest mods finally completed: S60, CM-DS, Spohn T/A, Drag Sway, LCA’s, PHBR
