3.73 Odd finding....
So ever since I bought my car (95 z28 m6) I have realized its faster than a stock LT car should be. I have raced several stock m6 and a4 LT powered fbodies and always win by at least 2 cars. I always assumed that it was due to my car being well taken care of as it is a 3 owner car (two of which being old men the other is me) with an excellent service record. I thought that until o drove my buddies 99 WS6. At 90 his tach is only showing 2k rpms. Mine is something like 2500 at 90mph. Then I looked up some charts and realized that I have a 3.73 rear end. Now when I got the car it had stock everything. Airbox, muffler, cat, paper filter, the works. Both previous owners said they never touched anything except for maintenance. So it got me wondering if maybe some cars came with 373 from the factory? I know for a fact that it is not a 342 ratio back there and according to the rpm-mph charts I in fact have a 373. Just curious if I was lied to or if its possible that it is a factory addition?
Hehehe....3:73's not likely but, ya never know what GM might have left to throw in there. Sooo, my suggestion is to pull the cover off for a fluid change, then simply start counting. No lie's there bud!
The ONLY way to find out what gear ratio is in your car is to remove the cover rotate the gear around until you see a stamped number that may resemble this:
41-10
39-10
You then divide the big number into the small number and you will get the actual gear ratio 41÷10=4.10
While you are there you can change the gear oil anyway.
41-10
39-10
