Gear Pattern Check Please?
Old 02-18-2012, 03:37 PM
hiltsy855's Avatar
Default Gear Pattern Check Please?
It's been a while since I've set up gears, I'm a little rusty LOL. This is the new 4.10 gear-set in my 8.8, could you guys please check the pattern for me and let me know what it needs if anything? BTW these are street gears for a street car & backlash is about .009". Thanks a million!!!
Old 02-18-2012, 04:08 PM
Big Al's Avatar
My best advice:
http://www.corral.net/tech/drivetrain/gears.html
Al 95 Z28
Old 02-18-2012, 07:47 PM
hiltsy855's Avatar
Thanks Al. That's good reading, this one is good too. I'm tired of reading & interpreting the info, I was hoping for some clear direction . It's been a long day - I'll give it another shot tomorrow.
Old 02-18-2012, 08:17 PM
wrd1972's Avatar
Tighten the backlash up up .002" - .004. The patterns should center up a tad more but you are very close.
Old 02-18-2012, 09:19 PM
Schitzo's Avatar
I'm guessing you are using FRPP gears which are now made by face hobbing.
If that is the case, as mentioned above, decrease backlash.
The minimum spec per Ford is 0.008" but with hobbed gears, you can run a much tighter backlash.
Old 02-19-2012, 07:28 AM
hiltsy855's Avatar
Perfect. I'll do the final install on the pinion and reduce BL a little. Yes, they are Ford Racing gears. Thanks guys.
Old 02-19-2012, 10:27 AM
hiltsy855's Avatar
Here is the pattern with .006-.007 backlash. Looks good to me. Thanks again guys!
Old 02-19-2012, 02:24 PM
Schitzo's Avatar
Perfect
Old 02-21-2012, 12:12 AM
shepss217's Avatar
looks good to me
Old 02-21-2012, 01:48 AM
HoLLo's Avatar
That pattern is ready to be ran!
Old 02-21-2012, 08:30 PM
hiltsy855's Avatar
Thanks for the confirmation guys. Adjusting the backlash really made a difference.
Old 02-21-2012, 09:12 PM
wrd1972's Avatar
Run it.
Old 02-21-2012, 09:47 PM
shepss217's Avatar
go give her hell
Quick Reply: Gear Pattern Check Please?
