Vibration after rearend install
#42
I'll give my two cents. I had similar issues recently. I fixed it yesterday. I tried a few things. I messed with pinion angle numerous times. My tailshaft bushing looked perfect and had min play in it. I put another tailshaft housing in with a new bushing installed. I also spent extra time to make sure the ujoints were fully seated in the rear. Very easy to mess that up the way these splicer joints fit so tight. I tapped them into the seat with a rubber mallet.
My vibration is gone! For the small price a bushing costs, it would be worth a try.
Edit, I reread the thread. Seems you have already tried this.
#43
You said you tried 2 different driveshafts, what yoke(s) did they use? I had a yoke from strange that just didnt fit in the tailhousing right. It wobbled a little, like it was loose in the bushing or the splines werent cut right. I bought a new yoke from Mark Williams and it fixed the problem. Also verify that the driveshaft is the correct length, that could cause the same problem.
Ryan
Ryan
#44
Mine was a low mile transmission, so I knew the problem wasnt the bushing. So I ordered a new yoke from Mark Williams. Strange wasn't really much help with the yoke, they test fit one on one of their cars, said it fit right and they were all machined the same. They took it back though, so that was good. I read a couple of other people having problems with the strange C/M yoke. The Mark Williams yoke fit much tighter on the splines, the barrel diameter was a few thousandths bigger and it made the problem disappear. Now I switched to a 32 spline yoke, so if you need a 27, let me know. I am selling mine.
Ryan
Ryan
#45
Ryan
Ryan
#46
So is Strange replacing these with properly tolerenced parts?
I have to get to work now, but will mic it tonight and see if the OD is different.
I just got my transmission in Sunday and bought the PST DS with the Strange yoke last fall from a site sponsor. After reading this thread I went out and tried the fit and guess what, it has play. My 7 year old 350 pass Spicer is nice and tight with no play. The Strange is sloppy in fit, WTF?
Any way I bought it from a sponsor and just sent him an email to see what the options are.
Any one else had PST resolve this?
#47
I think their opinion was that my car was some kind of fluke. I think that the way that the splines are cut/rolled, however they do it, is the problem. The O.D. was pretty close, but there is alot of difference in the splines. The Mark Williams yoke fit my car alot better.
Ryan
Ryan
#48
I have measured both the Spicer and the Strange Yokes. The Strange is 1.4995 OD and the Spicer was 1.5021 OD. When the picer is on there feels like there is zero play, the Strange moves alot. I plan to try them on and use a dial indicator to show movement at the u jonts center to see the difference out there.
I think you might have something on the slpines fit though. I need to check for rotational play too.
Who sells the Mark Williams unit?
#50
Ryan
Ryan
