Question about drive v6 driveshaft.
Old 04-26-2012, 08:30 AM
bad_408_vert's Avatar
Default Question about drive v6 driveshaft.
I'm doing a v6 to v8 swap.
So my question is if I can use the 3.8l v6 driveshaft with v8 drivetrain?
Old 04-26-2012, 12:01 PM
k_cash1432's Avatar
You can use it but your better off upgrading it all now while you have it out. The rearend would be the only thing to reuse since they are the same 10 bolt rearend and I'm changing mine to an 8.8 when I get my hands on one
Old 04-26-2012, 01:54 PM
^ Thanks for confirmation.
If the v6 can work, which is made out of steel .
Wouldn't that be upgrade since lot of high hp car owners end up swapping form aluminum DS to a steel one anyway?
Old 04-26-2012, 03:11 PM
t/a98's Avatar
They go to a much stronger chromoly. Better balancing and larger u joints. Stock is fine but when you make any power and bow your driveshaft and destroy your tail housing you'll see why people upgrade the driveshaft.
Old 04-26-2012, 04:46 PM
FirstYrLS1Z's Avatar
V6 driveshafts are 2 piece,V8 driveshafts are 1 piece.
Old 04-27-2012, 09:56 AM
Alright, will defintely need a DS from a v8 then.
Thanks guys
Old 04-27-2012, 05:01 PM
bwkmaro's Avatar
v6's stopped with 2 piece ds in 1998
Old 05-01-2012, 10:22 AM
lsxformie's Avatar
^^^^What he said.
Old 05-01-2012, 11:11 AM
cemlsx's Avatar
Correct , they are all interchangeable.. I currently run a one piece aluminium on my V6 ..
