whiine new 373
whiine new 373
Just got a set of 3.73 gears from motive installed today. Moved from stock 3.23's . I'm getting a little whine when decelerating. Is this normal? Any tricks to quiet this down a bit or does it go away a little with time. Also is a tune required after this mod. Feels like I lost a little low end power. Any help willl be great.
yeah from what the mechanic said they where measured correctly as far as backlash and pinion depth. I have read that there is a "break in period" is this true. I only drove it home, about three miles from the shop. Should i change fluid after a certain amount of miles ?
FWIW after I switched from 3.23 to 3.73 mine whined a little bit too, at around 50 mph. Everything was replaced, bearings , races, the works. Of course the installer said everything was set to spec.
He blamed it on my Spohn floor mounted TA (torque arm). But - it didn't whine with the 3.23 gears and with the same Spohn floor mounted TA before the switch.
Do you have an aftermarket TA or still have the stock TA?
As for me - should I bite the bullet and buy new Motive 3.23 gears.
Note: the way I see it, the car when I bought it was stock and the rear end didn't whine. So you pay someone to change gears and then it whines - my Moser is the same way - sounds like the 52 chevy truck I used to drive when I was a kid. Absolutely annoying to drive.
I also heard that Yukon and American Axle Manufacturing are the gears to buy for quiet operation. A little more initially but worth the investment. Also some of those gears are noisy by design. Alot of those gears are made of very hard metal alloys and will make noise regardless. These magazine order gears are just that.
Yeah mine whine a bit with decelaration. When i take my foot off the gas they have a little howl in them. Harder material could be understood I guess. I am running the stock torque arm and I heard nothing from my stock 3.23 but then again those gears where 17 yrs old plenty of wear on them . gonna run them for a few more miles see what happens. It's always something....
I agree with this. However, I've built a ton of rear ends and some of them just have some noise. The same installer can then turn out a rear end that's dead silent. Its a tricky deal. I would not really make it an issue (with the installer) just get used to the noise. Did you install the blue or orange box Motives?
Al 95 Z28
Same here. I wasted a lot of time on a 10 bolt I put 4.11's in, before I ever even moved it. No matter what I did the pattern would not come out right. I checked everything. So I knew up front it would be noisy and it didn't let me down It was in a V8 Pontiac Sunbird. When I had my shop I worked on lots of rear ends some guy put gears in that were noisy because of improper set up. I can count the one that I could fix without changing gears on one hand and have a few fingers left. If it's driven more than about 50 miles it's gone. Most were guys that just replaced the gears and used whatever shims were originally in there and expected it to work. And, sometimes it does.
Al 95 Z28
Al 95 Z28
I will have the rear end replaced at a shop where it has a lift where you can drive the car with it on the lift with suspension loaded. With that type of lift is it easier for the installer to get it right, or does it have to be on the ground and tested in order to hear whine?
When the installer installed my Moser, no one ever told me that we had to heat cycle the gears. It was on the dyno for a few runs, and then we drove it home from Indiana to Kansas.
Same for the installer who reinstalled my 3.42 gears in the Moser. They installed the gears and I drove it back home from Ok to Kansas without any heat cycling.
The 9" Ford is about the easiest rear to set up. A real Dana about the hardest. Why does that matter? Because most will just say it's close enough, because it's a lot of work to change it. With a Ford you can change pinion depth without much work, same for side to side ring gear adjustments and carrier preload. So you'er more likely to do it.
Al 95 Z28 w/S60
I just ordered Motive ring pinion and they told me the Orange and Black box is a better gear and it is more expensive than the blue box.
Whether that is accurate ???? Sometimes sales will tell you anything even though one part number might not be any better than the cheaper part number.
