Free 3.73's or buy 4.11's. 1999 m6 SS
Old 08-04-2012, 09:25 PM
im-not-guilty's Avatar
Default Free 3.73's or buy 4.11's. 1999 m6 SS
99 SS m6 all stock.
My rear diff is noisy . Leaky pinion seal and ran low on fluid.....
If I'm gonna rebearing it I would like to regear it also..
I have a set of 3.73's from a 2002 s-10 blazer sitting on the shelf.
Or should I buy a set of 4.11's.
I currently have 3.43's......
Any thing I should prepair for?
I Have traction control and wheel speed sensor,s at the end of each axle..
Thanks
Old 08-04-2012, 09:34 PM
HioSSilver's Avatar
3.73 are better for a bolt-on car and stock height tire. I was never impressed with the 4.10 in my car.
Old 08-04-2012, 09:36 PM
HioSSilver's Avatar
If you want 4.10 then I know where a set is for sale.
Old 08-04-2012, 09:45 PM
Send some more info thanks
Old 08-04-2012, 10:29 PM
ULTIMATEORANGESS's Avatar
Smile
4.10s is what most go with with m6s.
Old 08-04-2012, 10:48 PM
Any thing special I have do buy with the traction control
Old 08-04-2012, 11:21 PM
gears and install kit you should be good to go.
Old 08-13-2012, 09:27 PM
L84ARACE's Avatar
4:10's !!
Old 08-13-2012, 10:17 PM
guppymech's Avatar
I think you're more likely to end up with a quiet rear end by installing new gears instead of used gears. I like my 4.10s with the stock 26" tires.
Old 08-14-2012, 08:31 PM
fastsspr's Avatar
4.10 and not look back !!
Old 08-17-2012, 02:45 PM
zman1969's Avatar
I'd use the Factory 3.73's - you already have them correct? not a whole lotta difference to 4.10's and with those you will need to grind the paddle in your diff - the 4.10's ring gear is thicker and in the way of a stock paddle. I used to sell a bunch of OEM GM gears for cars like ours. IMO GM gears are quieter than a/m gears are, plus your 3.73s wont need break in - already done!
Quick Reply: Free 3.73's or buy 4.11's. 1999 m6 SS
