need help with 99 Z28 rear end, posi might be blown out!! help anybody...
hello all, i just got a 99 Z28 M6 for not a lot of money and while doing a fuel filter i wanted to check the rear end, so.. with both rear tires in the air in neutral i spun the left rear tire, the other tire spun the opposite way. that being said, i put the car IN GEAR while still in the air i spun the left rear tire and the other side tire did not spin. HMMMM. the RPO code on the door says it has the g80 and gu6 option. which is limited slip and 3.42 gear. i know that if you spin one tire by hand, and the other spins the opposite direction, you dont have posi...someone PLEASE help me out....
thanks guys..
-matt
thanks guys..
-matt
Thanks for any and all help guys
yup go do a burnout to confirm everything is fine. but the torsen works by using worm gears, when you spin the tires on the road the load on the tire from the pavement makes the worm gears climb on top of eachother and lock the tires together. with the car in the air there is no load on the tires so the worm gears dont work and the tires dont lock
What!! So if i got a Auburn In there I gave to use petroleum based gear oil? And friction modifier you mean the posi additive you get at the dealer right? I decoded all my rpo codes on the door sticker and I got no code.that told me what diff.I have. idea how to tell what diff.is.in there? U sure I cant use synthetic? I was gonna put synthet Royal Purple in everything ??????????
