Help with rear rebuild
Old 09-27-2012, 06:21 PM
Ryan Turner's Avatar
Default Help with rear rebuild
I've got a 98 SS with the GU5 RPO code. My rear is getting a little play in the ring and pinion, so im going to go ahead and rebuild it. I dont dragrace my car so the 10 bolt will be fine for my type of driving. As far as i know it has 3:23 gears with the GU5 correct? Should i just upgrade the ring and pinion and maybe some better axles or should i get a new differential and everything? I also plan on replacing the bearings regardless if i swap the axles out. Also if someone could point me in the direction of what parts to buy; that would be awesome!
Old 09-27-2012, 06:26 PM
murphinator's Avatar
gu5 is 323
Old 09-27-2012, 07:26 PM
ULTIMATEORANGESS's Avatar
get some motive 3.73s and a major rebuild kit.
Old 09-27-2012, 09:07 PM
Where could i get a rebuild kit? Should i rebuild the diff or just new gears and bearings?
Old 09-28-2012, 05:41 AM
id check some sponsors.
if its not a lot of trouble rebuild the whole thing.
Old 09-28-2012, 09:08 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
We offer a 10-bolt full rebuild kit with whatever gears you want. It will be complete with all shims bearings, gaskets, coverbolts, fluids, etc...
Here is a link to it on our site:
http://www.texas-speed.com/p-204-tex...d-package.aspx
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 09-28-2012, 07:24 PM
thats a nice setup ^ and Motive gears are supposed to be quiet as are GM gears , I wont throw others under the bus as sponsors sell others but some gears on the market are notoriously noisy
Old 09-28-2012, 09:20 PM
I have installed several different brands in my own personal vehicles such as motive, USA gear, Richmond, etc... And haven't had any trouble as long as they were setup correctly...
__________________
Old 09-28-2012, 09:44 PM
Smile
my 4.10s are quiet. im told heat cycling then changing your fluid makes a difference to seat things in properly.
Old 09-30-2012, 12:35 PM
Most of the manufacturers will have break-in procedures, and specific clearances for their gear sets. I have always followed these with my builds.
__________________
Quick Reply: Help with rear rebuild
