373 or 411 with my setup??
i got a f body camaro with a ms3 cam, heads, and 373s right now....the whine from the rear is annoying me so im going to to swap out the posi unit and change the gears. i love the 373s but would i bet better off with the 411s? i either run a MT/16 inch et street or a 15 or 16 inch MT Drag radial..... since the cam is a top end cam should i stay with the 37s or would i gain anything from going to the 411s?
http://www.hotrodpitstop.com/tool.php
Since you left out alot of information, here is a calculator for you. You can thank me later.
what other information do you need to know... i have no idea what the redlines are currently.. whatever the max redline is with a ms3 cam is .... the car is used for racing only not daily driver
how tall of a tire are you running ? 26" -28" etc is your car an A4 or M6.....
redline is what ever the cams is?? wth are you talking about. how bout you take it out and run it and tell us what it is.
The whine will still be there no matter what gear you are running if you have a 10 bolt. It probably isnt as bad as it sounds but you have a torque arm that is acting like a tuning fork and amplifying the noise. I have had VERY good luck in the past with the OEM manufactured gear sets and noise. The aftermarkets (Richmond, Motive) are more geared toward strength for their specific application. If you have a 10 bolt leave the 3:73 in place and save up for a larger rear.
<----Im watering my money tree for a rear right now.
