help with 10 bolt rebuild
So after my torque arm/lca and relo. bracket install my posi with 230k finally took a dump with my drag radials on. I can drive the car but im not going to drive it hard and im putting my street tires back on.
I found a used rear locally for cheap and my buddy is going to rebuild it for me. Im going to go w/ 3.73s since they should compliment my setup well and a full rebuild kit as well as a girdle.
A few things that I am unsure about are what brand gears are usually the quietest, and what is the usual break in period for new gears if there is one?
Thanks.
Thanks.
Buy a good rebuild kit with good torsen bearings. Make 100% certain your axle bearings are oe style and not repair bearings. People say motive and yukon are quitest. Check out mwcs site for break in...do exactly what it says. You need to heat cycle carefully.
Spend the extra $10 and get a solid pinion spacer.
