Rearend Wobble?
Old 06-25-2013, 02:50 PM
bouttime's Avatar
Default Rearend Wobble?
Dyno yesterday we noticed the rear looked to be wobbling. By "wobbling" I mean tire rotating unevenly on both sides. I just had lots of new parts installed including: 9inch shortened 3 inches each side, new driveshaft, torque arm, lca's, panhard, new rotors and pads from brake motive, custom boze wheels, qa1 coilovers front and rear. Does anyone know of any particular part that would cause this problem, other than the obvious reason of re-torquing the wheels back on the car to make sure they are flush? I pick the car up tomorrow so any feedback is appreciated thanks
Old 06-25-2013, 09:23 PM
S10xGN's Avatar
Maybe the lug stud holes/center hubs were machined off-center? Should be easy to track down, whatever it is...
Old 06-26-2013, 08:10 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Jack up the car and remove the wheels. At idle and in gear see if you may have a bent axle, if not it has to be in a wheel. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 06-26-2013, 08:40 AM
SSellers's Avatar
I've had new axles that would not allow the brake disc to seat correctly without either machining the axle or grinding out the rotor. As already mentioned, other possibilities are bent axle (been there) or problem with the wheels since they're custom. Correct lug spacing between new axles and wheels? Not a mix/match of 5x4.75" and 5x120mm?
Old 06-27-2013, 10:43 AM
bouttime's Avatar
How would I check this?
Also my HP numbers on the Dyno seem way low 350, should be more around 400, could the rear end wobble be causing the low dyno #'s
Old 06-27-2013, 11:05 AM
SSellers's Avatar
Using a micrometer. It's hard to get since the two are so close, only 0.7mm difference. It would be best if you knew how your custom wheels and axles were ordered.
One other thing, if the new axles don't have a hub lip sticking out to locate the wheels hubcentrically (most aftermarket ones don't, and most aftermarket wheels are not set up for it anyway) then you have to rely on properly installing the lugnuts to center the wheel using conical seat lug nuts. If you tighten down the first lug nut with an impact before getting all of them seated right or don't tighten in a crisscross pattern it is possible to have the wheel shifted slightly.
Quick Reply: Rearend Wobble?
