The Driveshaft Shop 3.5" Aluminum DS?
Anybody used DSS Driveshafts? I've talked to Frank and was impressed with the operation there. I'm thinking of going with a 3.5" Aluminum shaft setup for my 10-bolt with a 1350 U-Joint and adaptor, so I can run it now in my 10-bolt and then when it explodes, I can remove the adpator and run it as is in a 12-bolt or return to Frank and have it shortened for a 9" or S60.
I just want to make sure the rearend blows up and not the driveshaft. I have an expensive trans and exhaust (and not to mention me) that I'd like to keep scratch free. I am running a BMR DS Loop and it's nearly 4.5" wide at its narrowest, so I think it will work.
Just a shout out to Frank, I beat the pi$$ out of my 8.8irs gto conversion from them, nothing but the best imo. Just realized you had 4thgen shafts Frank, damn I may have to get one for my ws6 lol.
been awhile since i looked at driveshafts if i remember correctly the driveshaft shop had a really HD shaft rated at like 1000 hp but it was heavier than the inland aluminum only rated at 500 hp aprox same price so i chose the lighter weight. (going from memory) compare shipping weight to verify but i think the HD shaft was like 18 lbs vs maybe 10 lbs.
what is your hp rating & what the shipping weight? im very sorry if im posting wrong info. EDIT i called inland & their 3" weighs 16 lbs and their 3.5" weighs 18 lbs. EDIT2 im stock i checked my ppwk and when i ordered a 3" i was told shipping weight was 13lbs and the shaft was 11lbs so i was given bad info it appears. (from summit)
